Powered washer fluid assembly |
swood |
Nov 29 2009, 07:40 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics. First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself. Can I mount my pump in this area? I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet. |
FlacaProductions |
Jan 29 2020, 06:53 PM
Senior Member Group: Members Posts: 1,809 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
that should be correctly plumbed - the one with the barb goes to the nozzles because of the pressure outgoing.
is the tank vented so a vacuum isn't created? how long did you run it? Is it below the tank? |
SirAndy |
Jan 29 2020, 09:31 PM
Resident German Group: Admin Posts: 41,897 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
is the tank vented so a vacuum isn't created? (IMG:style_emoticons/default/agree.gif) You *need* a hole in the filler cap for this to work, otherwise the pump will never get any water out of the bottle. http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/shades.gif) |
ctc911ctc |
Jan 30 2020, 07:19 AM
Senior Member Group: Members Posts: 937 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Yes, I have the filler cap off - biggest hole I could find - (IMG:style_emoticons/default/smile.gif)
Thank you! is the tank vented so a vacuum isn't created? (IMG:style_emoticons/default/agree.gif) You *need* a hole in the filler cap for this to work, otherwise the pump will never get any water out of the bottle. http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 28th November 2024 - 09:35 AM |
