1.7 big bore fuel injection |
Damo |
Jan 29 2020, 11:22 AM
Newbie Group: Members Posts: 22 Joined: 2-January 20 From: United Kingdom Member No.: 23,789 Region Association: None |
Hi all. I’m in the process of converting my stock 1.7 to a big bore 1.9 and was looking to keep the stock fuel injection system if I can. I would just like to know if this is possible and how the original FI is tweaked, do I need to fit bigger injectors and mess with the throttle position etc etc. I’ve been told it’s possible but would like more detail so that I can continue. There must be quite a few out there that have done the big bore so hopefully someone will jump in. Thanks.
914_teener |
Jan 30 2020, 07:18 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I.f your gonna do a 1911 I.d ditch the D.jet and use L.jet with rebuilt 1.8 heads.
To try and make the 1.7 set up work is.nt worth it BTDT. You can make it work....yes. But the gains using the 1.7 D jet setup isn.t. |
Lo-Fi Version | Time is now: 26th December 2024 - 11:38 PM |
