Engine's out again, problem found..., previous post about compression leak.. |
Mike D. |
Dec 9 2004, 12:04 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,446 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
So, this past weekend I dropped the 6 to look for a compression leak on the number three cylinder. As soon as the cooling shroud came off it didn't take long to find it.
It doesn't look too bad and now I will finally know for sure what pistons and cams I have. Also have to take care of an oil leak on the front somewhere. (or rear depending on what car or book (IMG:style_emoticons/default/smile.gif) ) Check it out. Attached thumbnail(s) |
cnavarro |
Dec 9 2004, 12:26 PM
Cylinder Guru Group: Members Posts: 472 Joined: 30-December 02 From: Chicagoland! Member No.: 49 Region Association: None |
If it is a 2.0, that "head gasket" really doesn't help seal against that level of leakage, it's just more to reduce the combusion by-products getting blown into the stale air heat, or at least that's what I was told by an engine builder who does lots of 2.0 race engines.
Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance |
Lo-Fi Version | Time is now: 20th September 2024 - 05:03 PM |
