Door hinge, Bolts |
Door hinge, Bolts |
shane |
Feb 9 2020, 04:22 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
Preparing to bolt on the doors and was wondering did the hinge bolts going to the car have washers? Thanks in advance
914forme |
Feb 9 2020, 04:34 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
two actually per bolt
The PET is a great resource to have for these questions. https://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf hyper link was not working right, most likely due to the PDF file. |
shane |
Feb 9 2020, 05:05 PM
two actually per bolt The PET is a great resource to have for these questions. https://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf hyper link was not working right, most likely due to the PDF file. Great thanks for the heads up had no idea of PET file |
nihil44 |
Feb 9 2020, 06:50 PM
Member Group: Members Posts: 157 Joined: 28-January 12 From: Brisbane, Australia Member No.: 14,058 Region Association: None |
Shane,
PET says door hinge is fastened by M8 bolt (length not specified but I think the bolt is 27mm long and pointed to facilitate installation), a lock ring (aka spring washer) and a flat washer (A 8,4 - which I deduce is 8mm OD and 4mm ID) Good luck David |
nihil44 |
Feb 9 2020, 07:37 PM
Shane,
Another thought. To help installing doors, use one M8 stud in the top and bottom mountings in the door jamb to help you locate and steady the door while you put in the other bolts in. You can make a M8 stud from a M8 bolt with the hex head cut off. This concept is not mine but borrowed from another thread using this technique to install the bumpers. Installing the doors can almost be a one man job using this technique. Good luck again David |
Lo-Fi Version | Time is now: 27th December 2024 - 02:45 PM |
