> Crankshaft End Float and Oil Pump Questions, GA 2.0 Liter
motorvated
post Feb 9 2020, 06:49 PM
I am in the process of refreshing the top end of the referenced engine and I am measuring the crankshaft end float with the flywheel on the engine (haven't removed it yet) using a dial gauge magnetically mounted to the flywheel and and resting against the crankcase. I zero the dial gauge and pry the flywheel outwards using two large screwdrivers 180 degrees apart from one another until resistance is felt and the reading on the dial gauge is stable. I am getting a consistent reading of 0.006 in., against a specification maximum of 0.0051 in. per Haynes manual. Do I need to add a shim, or is this close enough? I will be replacing the flywheel with a lightened one, but wanted to get this measurement prior to removing the flywheel that is on it. I will replace the rear main seal when I replace the flywheel, but the measurement I'm now getting shouldn't be affected by the new flywheel, or will it? Photos of the zero'd dial gauge and the extended end float reading dial gauge are below.
Next question is about my oil pump. My engine gasket kit came with one paper gasket that appears to be for the oil pump outer cover. All the diagrams that I see for oil pump covers are not flat like mine, as pictured below.
My oil pump also has a paper gasket that is identical to the one for the outer cover that goes between the oil pump housing and the crankcase, while the diagrams seem to show an o-ring being used to seal the oil pump housing. Below is a photo of the mating surface of my oil pump housing.
The oil pump housing on my engine has no groove to accept an o-ring and used the paper gasket just like the one for the cover. Do I have a different oil pump on the engine? If so does anyone recognize it and can tell me about it.
Thanks!
porschetub
post Feb 10 2020, 12:04 PM
Your shims are most likely worn and hopefully your rear bearing thrust is ok,best way is to remove the flywheel ,take out the RMS and remove the old shims,bolt back on and test total end float then deduct the best clearance according to spec.
Replacement flywheel will be same as standard spec...the one (AA Performance) I fitted gave the same end float as the stock one I removed.
The pump you have is a Melling cast iron, not always the best choice as they can leak.
motorvated
post Feb 10 2020, 12:56 PM
QUOTE(porschetub @ Feb 10 2020, 11:04 AM) *
Is the capacity of the Melling pump greater than the stock Type IV pump? Is that probably why it was changed out by prior owner?
porschetub
post Feb 10 2020, 02:06 PM
QUOTE(motorvated @ Feb 11 2020, 07:56 AM) *
Sorry I don't remember,stock pump has small gears and I think the Melling is similar,go to the Samba.com and you will see plenty of info on these pumps.
Appears to be understood that the T4 has no need for big gear pumps.
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 09:10 PM
