> Windshield install with butyl - is butyl primer needed?
Kansas 914
post Jun 23 2017, 07:41 AM
I have brand new paint on the car. I remember the last time I had a windshield installed by I don't think the installer used primer.
Is it best to prime the frame first and is butyl primer the right stuff?
Like this? https://www.amazon.com/CRL-Pinchweld-Primer...uct_top?ie=UTF8
ConeDodger
post Feb 11 2020, 08:30 PM
Apex killer!
I did this alone but another set of hands would be good. I used butyl and primer. Didn’t cost that much more to do it right. I’ve been around here long enough to hear a few horror stories about cracked windshields because of the modern goop. The shops were even claiming butyl wasn’t legal in California anymore. Not true.
#1 thing to do “while you’re in there” so to speak. Replace the forward vinyl behind the dash. Given the 914rubber.com dash board quality, you should do that too...
Kansas 914   Windshield install with butyl - is butyl primer needed?   Jun 23 2017, 07:41 AM
76-914   I did not use any however I did prep with Lacquer ...   Jun 23 2017, 07:48 AM
Mark Henry   What size is the correct butyl...it's the tape...   Jun 23 2017, 08:00 AM
mepstein   What size is the correct butyl...it's the tap...   Jun 23 2017, 08:07 AM
Mark Henry   What size is the correct butyl...it's the ta...   Jun 23 2017, 08:09 AM
Kansas 914   [quote name='Mark Henry' post='2499469' date='Jun...   Jun 23 2017, 08:11 AM
Dave_Darling   Using the primer is not necessary, but it does hel...   Jun 23 2017, 09:24 AM
Perry Kiehl   Butyl primer will improve the seal. For $17 ...   Jun 23 2017, 09:35 AM
Kansas 914   Butyl primer will improve the seal. For $17...   Jun 23 2017, 10:45 AM
Mikey914   no primer required New paint not needed for sure....   Jun 23 2017, 02:39 PM
bbrock   With luck, I'll be facing this task in the not...   Jun 23 2017, 05:58 PM
Dave_Darling   Other than originality, are there reasons to stick...   Jun 23 2017, 10:07 PM
bbrock   Other than originality, are there reasons to stic...   Jun 23 2017, 10:49 PM
porschetub   Other than originality, are there reasons to stic...   Feb 12 2020, 01:04 PM
Perry Kiehl   Butyl tape is a consistent thickness, in this case...   Jun 23 2017, 09:10 PM
Montreal914   For the rear window, I have used 5/16 butyl about ...   Jun 23 2017, 09:45 PM
stevegm   914rubber’s kit is 9.5 mm, which is 3/8”. I h...   Feb 11 2020, 07:22 PM
bbrock   914rubber’s kit is 9.5 mm, which is 3/8”. I ...   Feb 11 2020, 08:55 PM
stevegm   914rubber’s kit is 9.5 mm, which is 3/8”. I...   Feb 11 2020, 09:11 PM
bbrock   [quote name='bbrock' post='2785159' date='Feb 11 ...   Feb 11 2020, 09:36 PM
stevegm   [quote name='stevegm' post='2785165' date='Feb 11...   Feb 11 2020, 09:55 PM
914werke   Other than originality, are there reasons to stic...   Feb 11 2020, 08:18 PM
ConeDodger   I did this alone but another set of hands would be...   Feb 11 2020, 08:30 PM
lierofox   https://www.amazon.com/gp/product/B00473W5V...=UTF...   Feb 11 2020, 08:32 PM
stevegm   https://www.amazon.com/gp/product/B00473W5V...=UT...   Feb 11 2020, 09:10 PM
lierofox   So you just put the primer on the windshield chan...   Feb 12 2020, 01:06 PM
mepstein   The warmer the better. Mark / Mikey explained the ...   Feb 12 2020, 01:20 PM
- Lo-Fi Version Time is now: 27th December 2024 - 07:41 PM
