Windshield install with butyl - is butyl primer needed? |
Kansas 914 |
Jun 23 2017, 07:41 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I have brand new paint on the car. I remember the last time I had a windshield installed by I don't think the installer used primer.
Is it best to prime the frame first and is butyl primer the right stuff? Like this? https://www.amazon.com/CRL-Pinchweld-Primer...uct_top?ie=UTF8 |
stevegm |
Feb 11 2020, 07:22 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
914rubber’s kit is 9.5 mm, which is 3/8”.
I have also heard 5/16” is correct, which is 7.94 mm. Does anybody know which is correct? I want to use stock windshield trim. Has xx anyone used either size with chrome? |
bbrock |
Feb 11 2020, 08:55 PM
914rubber’s kit is 9.5 mm, which is 3/8”. I have also heard 5/16” is correct, which is 7.94 mm. Does anybody know which is correct? I want to use stock windshield trim. Has xx anyone used either size with chrome? The factory manual specs 8mm butyl for both front and rear glass. Despite having a fresh 3/8" 914Rubber kit on hand, I bought 5/16" rope for the rear and it worked perfectly. I will use the same when I do the windshield. |
stevegm |
Feb 11 2020, 09:11 PM
914rubber’s kit is 9.5 mm, which is 3/8”. I have also heard 5/16” is correct, which is 7.94 mm. Does anybody know which is correct? I want to use stock windshield trim. Has xx anyone used either size with chrome? The factory manual specs 8mm butyl for both front and rear glass. Despite having a fresh 3/8" 914Rubber kit on hand, I bought 5/16" rope for the rear and it worked perfectly. I will use the same when I do the windshield. Where did you find the 8mm butyl? Locally? |
Lo-Fi Version | Time is now: 27th December 2024 - 08:21 PM |
