> Stock steering wheel installation questions, what parts to i need to put back on a stock wheel?
DRPHIL914
post Feb 12 2020, 12:29 PM
Dr. Phil
So I had a aftermarket wheel on my car when I bought it 12 years ago, and about 1-2 years into my ownership I scored an Ebay deal $50 for a very nice wood wheel that is now in the car. I have been looking for a nice original wheel for a long time and recently was able to acquire one. So as I look at the OEM one it looks like I am missing the horn button, a canceling ring possibly too. not sure what else, a spring maybe? if anyone has pictures it would be helpful.
What I currently have is the Nardi wood one that is attached to the stock column. it is metal, about 3" long, and then the wheel screws to that and the rubber center cover goes over it and the wire pulls thru and is clipped to the center hole button.
My new OEM ones has a very nice center horn part, and I did read about the counter clockwise turn to remove that. it looks like it will slide onto the spined shaft once I take the spacer/mount off that is on there now, and just bolt on the stock wheel?
I guess I need to know in what order the parts go back on. Where does the canceling ring etc go ?
I pulled up one factory diagram and that kind of gives me an idea, and SMC has the rebuild kits with a horn button, spring, and rubber center piece that goes in there. but I have not seen all this assembled, so some guidance is requested.
Thanks.
Phil
rhodyguy
post Feb 12 2020, 02:46 PM
That wheel will look good in the car.
DRPHIL914   Stock steering wheel installation questions   Feb 12 2020, 12:29 PM
DRPHIL914   Here is a few pictures, old new-old etc and the r...   Feb 12 2020, 12:34 PM
mepstein   No spring or horn plunger on a mid or late car. Yo...   Feb 12 2020, 12:53 PM
DRPHIL914   No spring or horn plunger on a mid or late car. Y...   Feb 12 2020, 01:01 PM
DRPHIL914   This? Ok   Feb 12 2020, 01:03 PM
mepstein   This? Ok Yes. I have an extra plastic hub if you...   Feb 12 2020, 01:17 PM
DRPHIL914   This? Ok Yes. I have an extra plastic hub if yo...   Feb 12 2020, 01:46 PM
DRPHIL914   [quote name='DRPHIL914' post='2785317' date='Feb...   Feb 12 2020, 05:34 PM
rhodyguy   That wheel will look good in the car.   Feb 12 2020, 02:46 PM
DRPHIL914   That wheel will look good in the car. I like my...   Feb 12 2020, 03:00 PM
mepstein   I wonder if the wrap marks would steam out.   Feb 12 2020, 03:07 PM
DRPHIL914   I wonder if the wrap marks would steam out. They...   Feb 12 2020, 03:09 PM
DRPHIL914   Also the 2 end tabs of the spring thing look bent,...   Feb 12 2020, 05:39 PM
mepstein   So good news. You have the correct hub and batwing...   Feb 12 2020, 05:46 PM
FlacaProductions   Looks like you may need this as your horn wire tab...   Feb 12 2020, 05:56 PM
mepstein   Looks like you may need this as your horn wire ta...   Feb 12 2020, 06:04 PM
DRPHIL914   [quote name='FlacaProductions' post='2785389' dat...   Feb 12 2020, 09:21 PM
DRPHIL914   Looks like you may need this as your horn wire t...   Feb 13 2020, 09:49 AM
rhodyguy   Mark Heard had found the little white plastic wash...   Feb 13 2020, 11:26 AM
mepstein   Mark Heard had found the little white plastic was...   Feb 13 2020, 11:51 AM
DRPHIL914   Mark Heard had found the little white plastic wa...   Feb 13 2020, 12:06 PM
DRPHIL914   Mark Heard had found the little white plastic was...   Feb 13 2020, 12:05 PM
rhodyguy   Inadvertent horn blasts always result in a 1 finge...   Feb 13 2020, 12:13 PM
- Lo-Fi Version Time is now: 27th December 2024 - 10:20 AM
