> Headlight issue, High beams don't stay on?
ewdysar
post Dec 9 2004, 05:35 PM
What happens here, stays here.
So my high beams don't stay on. They light up while I've got the lever pulled back but they go dark when I let go. Even the blue indicator works in sync with the lights themselves, lit while they're on and off when they're dark. The low beams work normally, they turn on on the next cycle of the switch and remain on until cycled again (see above). The green parking light indicator works as it should. I would like to get this straightened out before I install the H4's sitting in their boxes.
The car did sit for 13 years, in a garage until I moved to a house with no garage for the last year.
I'm hoping this sounds familiar to someone here...
TIA,
Eric
Aaron Cox
post Dec 9 2004, 05:37 PM
Professional Lawn Dart
does the relay click when high beams engage?
i bet its a relay issue
ewdysar   Headlight issue   Dec 9 2004, 05:35 PM
Aaron Cox   does the relay click when high beams engage? i be...   Dec 9 2004, 05:37 PM
ewdysar   I'll have to check when I get home...   Dec 9 2004, 05:43 PM
Dave_Darling   I'd bet on a faulty relay. You may be able to...   Dec 9 2004, 05:52 PM
vsg914   Like dave said, headlight relay. I had exactly the...   Dec 9 2004, 05:58 PM
94teener   Yes, it's your dimmer relay, symbal "J" on the...   Dec 9 2004, 06:45 PM
DJsRepS   Unless the relay has a catch / latch built in when...   Dec 10 2004, 06:54 AM
vsg914   Oh my god, he said Dave Darling may be wrong! ...   Dec 10 2004, 07:20 AM
scott thacher     Dec 10 2004, 08:42 AM
914GT   It's a latching relay, at least on a 74. The ...   Dec 10 2004, 09:15 AM
ewdysar   Let me see if I've got this right (probably ov...   Dec 10 2004, 01:34 PM
Dave_Darling   Yup, that's how it works! I'm not sur...   Dec 10 2004, 05:21 PM
DJsRepS   Well at least I worded it right as in (may be wron...   Dec 10 2004, 05:33 PM
ewdysar   OK, so my replacement relay finally showed up and ...   Jan 5 2005, 04:41 PM
ClayPerrine   IIRC, you have to add a jumper wire to connect pin...   Jan 5 2005, 05:05 PM
ewdysar   Man, I love this board. Quick answers to obscure ...   Jan 5 2005, 05:16 PM
DJsRepS   Sounds like the new relay may not be correct , ext...   Jan 6 2005, 06:49 AM
Dave_Darling   The old relay has been NLA for almost a couple dec...   Jan 6 2005, 11:46 AM
ClayPerrine
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 09:11 AM
