> Should my rear wheels turn, A little help
n2j2ryan
post Feb 14 2020, 03:20 PM
This seems like an easy question, but I really can't find the answer. I have the car on the hoist and we are almost ready to turn over for the first time. It seems like we are able to shift though all of the gears (without engine on). My question is, even though it is in gear, it is fairly easy to turn the wheels. Is that normal? Thanks for your help?
BeatNavy
post Feb 14 2020, 03:34 PM
It's pretty easy to turn the wheels because of the differential. You're turning one wheel, and the other rear wheel will rotate the opposite direction. In other words, you're not rotating the engine -- just the internal gearbox parts. If you want to turn the engine, you need to lock one of the wheels (typically I use a breaker bar and 19 mm socket, and since my car is on a mid-rise lift I use the floor jack handle wedged against the floor). It's easiest to move the engine when car is in a higher gear, like 5th. At that point, it's still pretty easy to rotate the one wheel and turn the engine.
Edit: beat me to it (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 27th December 2024 - 03:17 PM
