> LED headlight load for Fogs. ?
bandjoey
post Feb 15 2020, 01:01 PM
bandjoey
Three years ago when LED headlights started being offered for 914 I bought a set from Vintage lighting. This week The driver side headlight started blowing a fuse every time the lights were turned on. I switched out to a sealed beam light and it works fine. So that LED bulb must’ve gone bad. I looked at the $99 replacement bulb set at 914 rubber and there’s a statement that says if you have fog lights be sure and add a load to make them work. So if I go that route how do I add a load? I am also considering buying the new complete LED 7” headlight set that says plug and play as an entire unit. Will I run into the same problem with that unit?
- Lo-Fi Version Time is now: 28th December 2024 - 01:03 AM
