914 in-car spares kit, What spare parts do you keep in your 914? |
horizontally-opposed |
Feb 15 2020, 08:05 PM
Advanced Member Group: Members Posts: 3,455 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I used to carry a lot more spares with me before I pulled my car apart for paint, and then converted it to a 911 engine. I wasn't much concerned about originality or "concours" correctness...just didn't want to get stranded. I'd like to get back after that.
Back then it was: 15x5.5 Gasburner with 165R15 tire (lighter full-size spare) 944 scissor jack (lighter, and my jack points were suspect) Tool kit (not the original...) Fuses + relays + bulbs Fan belt Clutch clevis pin Clutch cable (under rear trunk carpet) Throttle cable (under rear trunk carpet) If you were going to do it now, or are doing it, what would be/is in your kit? EDIT: Going to make a running tally for (my) "ideal kit" based on the above and other ideas on this thread: Front trunk Full-size spare on light alloy wheel Aluminum scissor jack (in lieu of stock steel jack) Tool kit (original or roll your own), breaker bar w/19mm soft socket Fuses, relays, bulbs, clutch clevis, fan belt, fuel filter, select ignition parts Extra motor oil Rear trunk Clutch cable (laid flat under trunk carpet) Throttle cable (laid flat under trunk carpet) This thread has a number of other good ideas—as well as some fun ones—but the list above focuses on items that could be tough to get in a pinch but won't add much weight or take up a lot of space. Past the spare tire, jack, and tools, very little weight at all. I am sure everyone's take on "smart" things to bring along differs, particularly for a longer trip, but keep the ideas coming. They might help someone new to 914s out…as well as those of us who aren't. (IMG:style_emoticons/default/smile.gif) Especially the tequila... |
KSCarrera |
Feb 16 2020, 09:26 AM
Member Group: Members Posts: 320 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
jim_hoyland |
Feb 16 2020, 03:43 PM
Get that VIN ? Group: Members Posts: 9,598 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Throttle cable, clutch cable, cable ties, 19mm socket and breaker, and a small adjustable wrench. Oh, and my iPhone... And one of these: Boxster 986 spare wheel/tyre (lightweight and same diameter overall as the 195/65x15s I have on the car) and matching alumin(i)um jack. (IMG:style_emoticons/default/agree.gif) Great set for the front trunk Attached image(s) |
DickSteinkamp |
Feb 16 2020, 06:50 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
Throttle cable, clutch cable, cable ties, 19mm socket and breaker, and a small adjustable wrench. Oh, and my iPhone... And one of these: Boxster 986 spare wheel/tyre (lightweight and same diameter overall as the 195/65x15s I have on the car) and matching alumin(i)um jack. (IMG:style_emoticons/default/agree.gif) Great set for the front trunk My frunk is filled with radiator, so I carry the 986 spare in the trunk... (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20876-1581900635.1.jpg) The roof panel still fits and clips into the stock holders. The threaded hole for the hold down and the grommet in the trunk carpet were already there. The 986 spare in either location is the hot setup (especially if you run 195/65/15s). My method is...shake down your car if it is a recent build and fix anything that pops up. Get some miles on it (500 or so) and carry some tools during that process. After that, carry as many tools as you carry with your daily drivers...for me it's zero...after all, how many tools were carried by 914 owners when these cars were DD's? |
Feb 16 2020, 07:11 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20876-1581900635.1.jpg) The roof panel still fits and clips into the stock holders. The threaded hole for the hold down and the grommet in the trunk carpet were already there. You know, in all the years I've had my 914, I've looked at that threaded hole there and never thought about or realized it was ready to go for that use. Very cool. |
DRPHIL914 |
Feb 17 2020, 07:12 AM
Dr. Phil Group: Members Posts: 5,813 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20876-1581900635.1.jpg) The roof panel still fits and clips into the stock holders. The threaded hole for the hold down and the grommet in the trunk carpet were already there. You know, in all the years I've had my 914, I've looked at that threaded hole there and never thought about or realized it was ready to go for that use. Very cool. (IMG:style_emoticons/default/aktion035.gif) Neither did I! |
Lo-Fi Version | Time is now: 5th February 2025 - 02:40 AM |
