> 1.7 d-jet '73 almost running
isdyl
post Feb 29 2020, 06:15 AM
Region Association: England
Hi all - so I've refitted d-jet on my 1.7 which had a single weber when I bought it. It's almost running but I've run out of ideas as to what to adjust or check. I've recorded a video of it starting. You'll hear that it starts quite lumpily and wants to stall. I manage to get the revs up by feathering the throttle and they go up to 2.5 or 3000 revs on their own for a second, and then it all dies again. I can keep it running by feathering the throttle again.
https://www.youtube.com/watch?v=Y06kdQC2IZg
Fuel pressure when running is 2 BAR. Theres no cold start valve connected. All injectors are 'squirting' as I took them out and checked in a jam jar. I've tried adjusting timing, mixture screw, air screw. I haven't checked the valve clearances yet but have had the distributor in 100 different settings with no improvement. I just wondered if anyone has any ideas please?
Thanks, Dylan
BeatNavy
post Feb 29 2020, 06:45 AM
I will add that if you've had the distributor in 100 different settings you are probably struggling to even know which direction to go at this point. I've been there, and it's usually caused by timing mark confusion or even a distributor gear being aligned differently than stock. I'd put the engine at TDC. Verify where the timing mark is on the fan (and verify that you know which mark is 27 BTDC). See if the rotor is generally pointing toward plug 1. Understand which way the fan rotates with engine running and which way you need to turn the distributor to advance (CCW to advance, CW to retard).
You need to get it within the right "ballpark" so you can make fine adjustments.
isdyl
post Feb 29 2020, 06:54 AM
Yes I'm not sure where it is set now! I initially set it statically to TDC (the white mark I think) and it started in a similar fashion to the video. I then moved it in about 1 degree increments about 30 times in both directions, each time starting it to see if it would improve the running. This is why I assumed it wasn't a timing issue as I'd tried it in every position possible! I'll check the valve clearances. It's something I'll need to do as some point anyway.
Dylan
QUOTE(BeatNavy @ Feb 29 2020, 06:45 AM) *
BeatNavy
post Feb 29 2020, 06:57 AM
Don't forget that dwell though (assuming you have a conventional dizzy with points)! If that's not in spec that'll cause a host of issues too.
Good luck, Dylan!
(IMG:style_emoticons/default/beer.gif)
QUOTE(isdyl @ Feb 29 2020, 07:54 AM) *
Dylan
isdyl   1.7 d-jet '73 almost running   Feb 29 2020, 06:15 AM
BeatNavy   You haven't run out of ideas - you haven't...   Feb 29 2020, 06:29 AM
isdyl   Ok thanks - I was hoping to avoid climbing under t...   Feb 29 2020, 06:41 AM
BeatNavy   Ok thanks - I was hoping to avoid climbing under ...   Feb 29 2020, 06:52 AM
BeatNavy   I will add that if you've had the distributor ...   Feb 29 2020, 06:45 AM
isdyl   Yes I'm not sure where it is set now! I in...   Feb 29 2020, 06:54 AM
BeatNavy   Don't forget that dwell though (assuming you h...   Feb 29 2020, 06:57 AM
TheCabinetmaker   Have you checked vacuum on the mps? How about the ...   Feb 29 2020, 06:02 PM
Bleyseng   Have you checked vacuum on the mps? How about the...   Feb 29 2020, 07:48 PM
Spoke   It would help to have an AFR sensor to tune your F...   Mar 1 2020, 12:08 AM
isdyl   Hi - Thanks for your replies. I have checked the h...   Mar 1 2020, 02:07 AM
isdyl   Follow up - TPS is all working correctly. Hi - T...   Mar 1 2020, 06:56 AM
euro911   :agree: on the valve adjustment taking priority. M...   Mar 1 2020, 02:45 AM
isdyl   Thanks - I'd better get under that car.... ...   Mar 1 2020, 03:09 AM
BeatNavy   These are legit suggestions, but IMO you do have t...   Mar 1 2020, 06:59 AM
isdyl   Great - thanks. I'll get on to it. D These ...   Mar 1 2020, 10:33 AM
Tdskip   Just a thought - you have flow when testing the in...   Mar 1 2020, 04:40 PM
isdyl   Hi - there is a cold start injector but it’s not...   Mar 2 2020, 12:47 AM
ndfrigi   Hi - there is a cold start injector but it’s no...   Mar 2 2020, 01:03 AM
isdyl   Yes that’s about 2 bar - should it hold at that ...   Mar 2 2020, 01:13 AM
BeatNavy   I've heard conflicting things on whether it sh...   Mar 2 2020, 06:02 AM
isdyl   Thanks very much, and yes I'm on the case re t...   Mar 2 2020, 07:29 AM
isdyl   Hi all, So I've checked the valve gaps and all...   Mar 14 2020, 10:59 AM
914_teener   Hi all, So I've checked the valve gaps and al...   Mar 14 2020, 12:22 PM
porschetub   [quote name='isdyl' date='Mar 15 2020,...   Mar 14 2020, 02:58 PM
Bleyseng   We check a MPS by putting 15 hg of vacuum on them ...   Mar 14 2020, 12:54 PM
isdyl   Thank you. I'll do as you suggest. Dylan   Mar 14 2020, 01:56 PM
TheCabinetmaker   Just because the mps holds vacuum does not mean it...   Mar 14 2020, 02:48 PM
isdyl   Thank you for your suggestions. From the video I p...   Mar 15 2020, 04:11 AM
BeatNavy   Go ahead and take out and clean the dizzy as Porsc...   Mar 15 2020, 05:57 AM
isdyl   Will do, and thanks again for your help. Dylan G...   Mar 15 2020, 11:43 AM
ClayPerrine   Dylan, That stuff sat in my garage for years bef...   Mar 16 2020, 11:44 AM
isdyl   Thanks Clay - I’ll do all those things. There wa...   Mar 16 2020, 12:10 PM
PCH   We've recently problem solved the following: G...   Mar 16 2020, 12:18 PM
isdyl   Thanks. Actually there is a spare set of trigger p...   Mar 16 2020, 02:52 PM
isdyl   Hi, I've spent a long time trying to improve t...   Apr 15 2020, 10:07 AM
BeatNavy   There are some vagaries about which sensor you sho...   Apr 15 2020, 10:32 AM
isdyl   Hi - yes I'm sure I have the timing & dwel...   Apr 15 2020, 10:44 AM
isdyl   Oh I forgot to say that it will only 'tick ove...   Apr 15 2020, 10:48 AM
isdyl   I swapped the sensor out for a 2k resistor just to...   Apr 15 2020, 01:25 PM
BeatNavy   So you just put a 2k resistor between wiring harne...   Apr 15 2020, 01:48 PM
isdyl   Yes, just the resistor between the harness wire an...   Apr 15 2020, 02:11 PM
Bmw635   Check your fuel filter as it may be clogged. I flu...   Apr 15 2020, 02:25 PM
isdyl   Thanks - I've had that on a few previous cars ...   Apr 15 2020, 02:30 PM
ctc911ctc   Hi, I went down all of the paths that you did wit...   Apr 15 2020, 03:42 PM
isdyl   Thanks - ok so I've done a bit of testing this...   Apr 16 2020, 03:22 AM
isdyl   Hi - sorry to keep asking questions - I'm stil...   Apr 20 2020, 03:36 AM
ctc911ctc   Getting all of those leaks will result in a fine r...   Apr 20 2020, 08:14 AM
Bleyseng   yes, the spacers come with a paper gasket glued to...   Apr 20 2020, 07:55 AM
euro911   I didn't read through all the replies so I...   Apr 20 2020, 12:22 PM
isdyl   Hi, I haven't actually, but that's mainly ...   Apr 20 2020, 02:11 PM
ctc911ctc   Does it die as if you turned the key off? Or does ...   Apr 20 2020, 03:06 PM
isdyl   Not quite as quickly as if the key is switched off...   Apr 21 2020, 04:39 AM
isdyl   Hi - here's a video of it just running out of ...   Apr 21 2020, 10:51 AM
isdyl   Plugs are very sooty so maybe too much fuel? Quest...   Apr 24 2020, 11:42 AM
BeatNavy   You would see abnormally high fuel pressure.   Apr 24 2020, 11:49 AM
isdyl   Thanks I would love to solve this issue myself bu...   Apr 25 2020, 10:58 AM
isdyl   It's working! It's working!! I...   May 5 2020, 09:26 AM
BeatNavy   Was it a blown diaphragm on the MPS? I can't ...   May 5 2020, 12:20 PM
isdyl   I'm not sure - it seems to not leak when you s...   May 5 2020, 02:27 PM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 04:43 PM
