1.7 d-jet '73 almost running |
isdyl |
Feb 29 2020, 06:15 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi all - so I've refitted d-jet on my 1.7 which had a single weber when I bought it. It's almost running but I've run out of ideas as to what to adjust or check. I've recorded a video of it starting. You'll hear that it starts quite lumpily and wants to stall. I manage to get the revs up by feathering the throttle and they go up to 2.5 or 3000 revs on their own for a second, and then it all dies again. I can keep it running by feathering the throttle again.
https://www.youtube.com/watch?v=Y06kdQC2IZg Fuel pressure when running is 2 BAR. Theres no cold start valve connected. All injectors are 'squirting' as I took them out and checked in a jam jar. I've tried adjusting timing, mixture screw, air screw. I haven't checked the valve clearances yet but have had the distributor in 100 different settings with no improvement. I just wondered if anyone has any ideas please? Thanks, Dylan |
TheCabinetmaker |
Feb 29 2020, 06:02 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Have you checked vacuum on the mps? How about the throttle position switch? Condenser on the distributor? Have you actually checked or set dwell? Have you ohmed the head temp sensor?
Bleyseng |
Feb 29 2020, 07:48 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Have you checked vacuum on the mps? How about the throttle position switch? Condenser on the distributor? Have you actually checked or set dwell? Have you ohmed the head temp sensor? What he said.... Also is the advance working on the distributor? 45 grease on the weights inside can freeze em and so no advance. |
Lo-Fi Version | Time is now: 6th January 2025 - 04:49 PM |
