1.7 d-jet '73 almost running |
isdyl |
Feb 29 2020, 06:15 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi all - so I've refitted d-jet on my 1.7 which had a single weber when I bought it. It's almost running but I've run out of ideas as to what to adjust or check. I've recorded a video of it starting. You'll hear that it starts quite lumpily and wants to stall. I manage to get the revs up by feathering the throttle and they go up to 2.5 or 3000 revs on their own for a second, and then it all dies again. I can keep it running by feathering the throttle again.
https://www.youtube.com/watch?v=Y06kdQC2IZg Fuel pressure when running is 2 BAR. Theres no cold start valve connected. All injectors are 'squirting' as I took them out and checked in a jam jar. I've tried adjusting timing, mixture screw, air screw. I haven't checked the valve clearances yet but have had the distributor in 100 different settings with no improvement. I just wondered if anyone has any ideas please? Thanks, Dylan |
euro911 |
Mar 1 2020, 02:45 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) on the valve adjustment taking priority. My '71 (with a 1.7L at the time) would hunt for an idle when I bought it. I checked all the FI components, replaced all the vacuum and fuel lines, checked/adjusted the dwell & timing, all to no avail. After performing a valve adjustment, the idle hunting went away. One cylinder had the valves adjusted too tight.
The TPS board's traces can get worn down and cause dropouts. You may get by trying to clean the traces and repositioning the 'fingers' to a better looking portion on the trace(s). If the traces are real bad, 914 Rubber sells new reproduction TPS boards. |
Lo-Fi Version | Time is now: 6th January 2025 - 05:07 PM |
