1 day to Werks Reunion/Amelia |
stevegm |
Jan 18 2020, 06:25 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
4 days to Amelia!
I thought I’d start a thread for anyone getting your car ready for Werks Reunion/Amelia Island. I’d love hear about your progress. If you’re like me, you probably need some encouragement. I have no idea how a I will get the car ready in time. (IMG:style_emoticons/default/headbang.gif) But a deadline with some accountability will help. (IMG:style_emoticons/default/evilgrin.gif) My goal is to do something on it every day. We will see. So where are you on getting your car ready? Here is where I am starting: I made some more room in the garage and got it turned around today. But family duties kept me from getting anything else done. Here is what I need to do in the next month or so: Get engine running - rebuilt, but never run but for a few minutes at most Install carbs Pull the alternator back out because I get spark when I hook up battery - back plate of alternator grounding out? Put side windows and wing windows back in - Uggg Install new rubber Install windshield Install rear window Install engine lid and 3 powder coated grills Install headlight covers Install side rocker covers Install chrome Get new tires mounted on wheels Install master cylinder/bleed brakes Install shifter hook shift rod up Install interior - carpet, back pad, etc. Install new steering wheel I think that pretty much covers it. Attached thumbnail(s) |
stevegm |
Mar 1 2020, 07:52 PM
The bad news? I had to drop the engine/tranny again. The good news? I found the problem.
I dropped the motor because I had an alternator problem (huge spark when I hook up battery), and it is a lot easier to get the alternator out that way. Also, I had removed the halfshafts previously, and I figured it would make putting them back into the trailing arms much easier. The spark I was getting when I hooked the battery up was due to the back plate of the alternator grounding out on the lead inside of the alternator. See photo below. I guess I need to bend the outer plate a little. I got the half shafts in. But not much other progress today. I need to get the alternator checked tomorrow. I assume it grounding out may have damaged it. And I need to see about getting the gas tank flushed. At this point it isn’t looking good for getting the car to a state that it makes sense to take it to Werks Reunion. But I’m not giving up yet. If it makes it, however, it will still be an incomplete project. Just too much to do. I’m bummed. I wasn’t planning to take it to Hershey since we will be hauling booth stuff. So Luft would be the next available event to take it to, which I am not confident about being able to get a spot for. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 25th June 2024 - 07:08 PM |
