> 1.7 d-jet '73 almost running
isdyl
post Feb 29 2020, 06:15 AM
Region Association: England
Hi all - so I've refitted d-jet on my 1.7 which had a single weber when I bought it. It's almost running but I've run out of ideas as to what to adjust or check. I've recorded a video of it starting. You'll hear that it starts quite lumpily and wants to stall. I manage to get the revs up by feathering the throttle and they go up to 2.5 or 3000 revs on their own for a second, and then it all dies again. I can keep it running by feathering the throttle again.
https://www.youtube.com/watch?v=Y06kdQC2IZg
Fuel pressure when running is 2 BAR. Theres no cold start valve connected. All injectors are 'squirting' as I took them out and checked in a jam jar. I've tried adjusting timing, mixture screw, air screw. I haven't checked the valve clearances yet but have had the distributor in 100 different settings with no improvement. I just wondered if anyone has any ideas please?
Thanks, Dylan
Tdskip
post Mar 1 2020, 04:40 PM
Just a thought - you have flow when testing the injectors off the car by are you sure you are getting flow when on the car?
Question for the brain trust here - does his set up have a cold start injector or any other way to getting fuel to the car outside the four main injectors?
isdyl
post Mar 2 2020, 12:47 AM
Hi - there is a cold start injector but it’s not yet plumbed into the fuel hose that runs past it between cylinders 2 and 4. I did wonder a bit about fuel pressure and flow as I only get 2 bar when the pump is running. As soon as it stops running (like when the engine is off) the gauge drops to about 1.2 bar. I assumed it’s leaking back past the pump. D
QUOTE(Tdskip @ Mar 1 2020, 04:40 PM) *
ndfrigi
post Mar 2 2020, 01:03 AM
QUOTE(isdyl @ Mar 1 2020, 10:47 PM) *
fuel pressure should be between 28 and 31 psi. probably your fuel pump need replacement or getting low voltage.
isdyl   1.7 d-jet '73 almost running   Feb 29 2020, 06:15 AM
BeatNavy   You haven't run out of ideas - you haven't...   Feb 29 2020, 06:29 AM
isdyl   Ok thanks - I was hoping to avoid climbing under t...   Feb 29 2020, 06:41 AM
BeatNavy   Ok thanks - I was hoping to avoid climbing under ...   Feb 29 2020, 06:52 AM
BeatNavy   I will add that if you've had the distributor ...   Feb 29 2020, 06:45 AM
isdyl   Yes I'm not sure where it is set now! I in...   Feb 29 2020, 06:54 AM
BeatNavy   Don't forget that dwell though (assuming you h...   Feb 29 2020, 06:57 AM
TheCabinetmaker   Have you checked vacuum on the mps? How about the ...   Feb 29 2020, 06:02 PM
Bleyseng   Have you checked vacuum on the mps? How about the...   Feb 29 2020, 07:48 PM
Spoke   It would help to have an AFR sensor to tune your F...   Mar 1 2020, 12:08 AM
isdyl   Hi - Thanks for your replies. I have checked the h...   Mar 1 2020, 02:07 AM
isdyl   Follow up - TPS is all working correctly. Hi - T...   Mar 1 2020, 06:56 AM
euro911   :agree: on the valve adjustment taking priority. M...   Mar 1 2020, 02:45 AM
isdyl   Thanks - I'd better get under that car.... ...   Mar 1 2020, 03:09 AM
BeatNavy   These are legit suggestions, but IMO you do have t...   Mar 1 2020, 06:59 AM
isdyl   Great - thanks. I'll get on to it. D These ...   Mar 1 2020, 10:33 AM
Tdskip   Just a thought - you have flow when testing the in...   Mar 1 2020, 04:40 PM
isdyl   Hi - there is a cold start injector but it’s not...   Mar 2 2020, 12:47 AM
ndfrigi   Hi - there is a cold start injector but it’s no...   Mar 2 2020, 01:03 AM
isdyl   Yes that’s about 2 bar - should it hold at that ...   Mar 2 2020, 01:13 AM
BeatNavy   I've heard conflicting things on whether it sh...   Mar 2 2020, 06:02 AM
isdyl   Thanks very much, and yes I'm on the case re t...   Mar 2 2020, 07:29 AM
isdyl   Hi all, So I've checked the valve gaps and all...   Mar 14 2020, 10:59 AM
914_teener   Hi all, So I've checked the valve gaps and al...   Mar 14 2020, 12:22 PM
porschetub   [quote name='isdyl' date='Mar 15 2020,...   Mar 14 2020, 02:58 PM
Bleyseng   We check a MPS by putting 15 hg of vacuum on them ...   Mar 14 2020, 12:54 PM
isdyl   Thank you. I'll do as you suggest. Dylan   Mar 14 2020, 01:56 PM
TheCabinetmaker   Just because the mps holds vacuum does not mean it...   Mar 14 2020, 02:48 PM
isdyl   Thank you for your suggestions. From the video I p...   Mar 15 2020, 04:11 AM
BeatNavy   Go ahead and take out and clean the dizzy as Porsc...   Mar 15 2020, 05:57 AM
isdyl   Will do, and thanks again for your help. Dylan G...   Mar 15 2020, 11:43 AM
ClayPerrine   Dylan, That stuff sat in my garage for years bef...   Mar 16 2020, 11:44 AM
isdyl   Thanks Clay - I’ll do all those things. There wa...   Mar 16 2020, 12:10 PM
PCH   We've recently problem solved the following: G...   Mar 16 2020, 12:18 PM
isdyl   Thanks. Actually there is a spare set of trigger p...   Mar 16 2020, 02:52 PM
isdyl   Hi, I've spent a long time trying to improve t...   Apr 15 2020, 10:07 AM
BeatNavy   There are some vagaries about which sensor you sho...   Apr 15 2020, 10:32 AM
isdyl   Hi - yes I'm sure I have the timing & dwel...   Apr 15 2020, 10:44 AM
isdyl   Oh I forgot to say that it will only 'tick ove...   Apr 15 2020, 10:48 AM
isdyl   I swapped the sensor out for a 2k resistor just to...   Apr 15 2020, 01:25 PM
BeatNavy   So you just put a 2k resistor between wiring harne...   Apr 15 2020, 01:48 PM
isdyl   Yes, just the resistor between the harness wire an...   Apr 15 2020, 02:11 PM
Bmw635   Check your fuel filter as it may be clogged. I flu...   Apr 15 2020, 02:25 PM
isdyl   Thanks - I've had that on a few previous cars ...   Apr 15 2020, 02:30 PM
ctc911ctc   Hi, I went down all of the paths that you did wit...   Apr 15 2020, 03:42 PM
isdyl   Thanks - ok so I've done a bit of testing this...   Apr 16 2020, 03:22 AM
isdyl   Hi - sorry to keep asking questions - I'm stil...   Apr 20 2020, 03:36 AM
ctc911ctc   Getting all of those leaks will result in a fine r...   Apr 20 2020, 08:14 AM
Bleyseng   yes, the spacers come with a paper gasket glued to...   Apr 20 2020, 07:55 AM
euro911   I didn't read through all the replies so I...   Apr 20 2020, 12:22 PM
isdyl   Hi, I haven't actually, but that's mainly ...   Apr 20 2020, 02:11 PM
ctc911ctc   Does it die as if you turned the key off? Or does ...   Apr 20 2020, 03:06 PM
isdyl   Not quite as quickly as if the key is switched off...   Apr 21 2020, 04:39 AM
isdyl   Hi - here's a video of it just running out of ...   Apr 21 2020, 10:51 AM
isdyl   Plugs are very sooty so maybe too much fuel? Quest...   Apr 24 2020, 11:42 AM
BeatNavy   You would see abnormally high fuel pressure.   Apr 24 2020, 11:49 AM
isdyl   Thanks I would love to solve this issue myself bu...   Apr 25 2020, 10:58 AM
isdyl   It's working! It's working!! I...   May 5 2020, 09:26 AM
BeatNavy   Was it a blown diaphragm on the MPS? I can't ...   May 5 2020, 12:20 PM
isdyl   I'm not sure - it seems to not leak when you s...   May 5 2020, 02:27 PM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 04:41 PM
