Door latch repair....., The importance of maintenance |
billh1963 |
Jul 13 2013, 02:34 PM
Car Hoarder! Group: Members Posts: 3,405 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
This is old news to those who have been around 914's for a while. But, for the newer owners this might be useful:
Decided today was a good day to fix 914 door latches. Two cars had inoperative passenger outside door latches and the drivers door on one of them was getting harder to open. I knew at that rate it wouldn't be long and I would be locked out of the car! Did the normal research (thread searches, reviewed the procedures in the Porsche workshop manual, etc) and figured I knew what to do. The plan was to replace the plastic cam pieces (I had purchased four new ones a couple of months ago) and clean/degrease the latch assemblies. The first door I tackled (inoperative outside latch on passenger door) had a broken cam as suspected. The cam was black. Isn't that a replacement unit? The latch mechanism inside the door was very grungy. Experimentation between purple power, simply green , gunk engine degreaser and brake cleaner showed that the best results were obtained by spraying the mechanism with gunk engine degreaser (gel) and letting it sit for 15-20 minutes. Rinse off and follow up with brake cleaner. YMMV. I sprayed the moving pieces with white lihium grease before reassembly. I cannot explain how nicely the door operates now. Just a slight pull on the door handle and the door pops open. The second door was the "good" drivers door. The cam looks to be original (white plastic) and in perfect shape. The door mechanism was very dirty and operated sluggishly. A good cleaning and the door now pops open with a light pull. The main purpose of this post is a warning on what was found on the other car. On that car the passenger door was not opening with the outside handle and it took a lot of effort to open the drivers door with the outside handle. On both doors, the cam had deformed from all the pressure exerted trying to activate the sticking latch mechanism. The picture below is the drivers door. The passenger door cam was deformed even further and would not push the latch. If I had waited much longer I would have been "locked" out of the car! I replaced the cams and after a thorough cleaning of the latch mechanisms (and new grease) the doors operate like new. This is a really simple project and I did four doors in about 3.5 hours. That was taking my time and doing other stuff while waiting for the degreaser to work. So, if your door latches are sticking, don't put off this project. It's easy and very rewarding! |
AZBanks |
Mar 2 2020, 03:39 AM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Both door locks on my car were so hard to turn that I was afraid the key would snap.
I just completely cleaned and lubed the handles and the latch mechanism and now they lock and unlock almost effortlessly. |
mepstein |
Mar 2 2020, 07:12 AM
914-6 GT in waiting Group: Members Posts: 19,684 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Both door locks on my car were so hard to turn that I was afraid the key would snap. I just completely cleaned and lubed the handles and the latch mechanism and now they lock and unlock almost effortlessly. It's really important to do that on all the latches, locks and cable pulls on our cars. The extra effort you need when they are gummed up is what bends and breaks the smaller parts. |
AZBanks |
Mar 2 2020, 11:11 AM
Both door locks on my car were so hard to turn that I was afraid the key would snap. I just completely cleaned and lubed the handles and the latch mechanism and now they lock and unlock almost effortlessly. It's really important to do that on all the latches, locks and cable pulls on our cars. The extra effort you need when they are gummed up is what bends and breaks the smaller parts. Looks like I've got an appointment with the frunk and the engine lid. The frunk takes a TON of effort to get the cable latch to pop. The engine lid isn't bad but as long as I am working on latches, I guess I'll get them all. |
mepstein |
Mar 2 2020, 12:06 PM
Both door locks on my car were so hard to turn that I was afraid the key would snap. I just completely cleaned and lubed the handles and the latch mechanism and now they lock and unlock almost effortlessly. It's really important to do that on all the latches, locks and cable pulls on our cars. The extra effort you need when they are gummed up is what bends and breaks the smaller parts. Looks like I've got an appointment with the frunk and the engine lid. The frunk takes a TON of effort to get the cable latch to pop. The engine lid isn't bad but as long as I am working on latches, I guess I'll get them all. It's worth the time to pull the front latch release and cable from under the dash. Once it's all lubed up, it pops with just a light pull.You don't have to pull the cable on the engine lid, gravity will take care of distributing the lube. |
Lo-Fi Version | Time is now: 6th January 2025 - 05:53 PM |
