Replacing rusty jack points, So this is what it means to own a 914... |
Lilchopshop |
Mar 10 2020, 04:31 PM
Member Group: Members Posts: 75 Joined: 17-February 20 From: New York Member No.: 23,932 Region Association: North East States |
Pulled my rocker covers today to inspect for rot. Unfortunately I found significant rust on both jack points and the driver’s side long has a good size rust hole. I’m going to cut and patch the bad spots in the longs, but I’m trying to avoid a complete resto right now and I don’t want to get into exterior bodywork. The rear fenders are in pretty good shape but they seem to block access to the top flange of the jack point plate. Does anyone know if the jack points can be replaced correctly without cutting out a lower portion of the rear fender?
Attached thumbnail(s) Attached image(s) |
911GT2 |
Mar 11 2020, 08:58 AM
Member Group: Members Posts: 195 Joined: 2-March 11 From: The Netherlands Member No.: 12,773 Region Association: Europe |
Just out of curiosity. Do people leave the jackpoints off? Or are they structural?
rjames |
Mar 11 2020, 10:05 AM
I'm made of metal Group: Members Posts: 4,111 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Just out of curiosity. Do people leave the jackpoints off? Or are they structural? The jackpoints themselves aren’t structural, but the longs they attach to are. IMHO your car isn’t safe to drive until the longs are properly repaired. It looks like you’ve got quite a bit of rust to cut out and replace. If you decide to fix it, make sure you brace the car before you start cutting and welding. |
911GT2 |
Mar 11 2020, 11:00 AM
Just out of curiosity. Do people leave the jackpoints off? Or are they structural? The jackpoints themselves aren’t structural, but the longs they attach to are. IMHO your car isn’t safe to drive until the longs are properly repaired. It looks like you’ve got quite a bit of rust to cut out and replace. If you decide to fix it, make sure you brace the car before you start cutting and welding. I understand, but why place them back if they aren't structural and are a big reason for rust. (IMG:style_emoticons/default/confused24.gif) |
914e |
Mar 11 2020, 11:34 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Just out of curiosity. Do people leave the jackpoints off? Or are they structural? The jackpoints themselves aren’t structural, but the longs they attach to are. IMHO your car isn’t safe to drive until the longs are properly repaired. It looks like you’ve got quite a bit of rust to cut out and replace. If you decide to fix it, make sure you brace the car before you start cutting and welding. I understand, but why place them back if they aren't structural and are a big reason for rust. (IMG:style_emoticons/default/confused24.gif) They are not structural to the car, they are structural to supporting the jack point to the car structure. Not something you want to fail while changing a flat. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:20 PM |
