74 914 2.0 dJet slight hesitation |
nsargeant |
Mar 12 2020, 07:38 AM
Newbie Group: Members Posts: 12 Joined: 27-August 17 From: Vincennes, In Member No.: 21,381 Region Association: Upper MidWest |
In the quest for a perfect running 914 im getting oh so close. In the past I have replaced the tps with a new one that fixed the severe bucking/hesitation. The car ran so much better after that. What I am trying to figure out now is a random hesitation/hiccup that happens mostly during steady throttle when I am cruising on a highway. If I drive 30 miles it might happen once or twice. It seems pretty minor compared to the bucking I was having with the old tps. If I recall it has had this hesitation since I have owned the car for the last 3 years. I know the distributor does have a pertronix module in it. Ive recently changed replaced a few things listed below but still have that little hiccup. What would you guys investigate next?
Replaced: Fuel pump/filter Installed SS lines plugs, wires, rotor, (cap still looked new) tps sensor |
gonzo54 |
Mar 12 2020, 04:13 PM
Orange Crush Group: Members Posts: 227 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California |
I'm having the same problem with my 73 2.0 Djet. Happens around the same RPM or 55 MPH 5th gear. I've done a number of things suggested but have not replaced the TPS. MPS has not been adjusted-still sealed. Where can I purchase a replacement TPS and how hard is it to replace and calibrate?
-Rick Seal Beach |
BeatNavy |
Mar 12 2020, 04:36 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I'm having the same problem with my 73 2.0 Djet. Happens around the same RPM or 55 MPH 5th gear. I've done a number of things suggested but have not replaced the TPS. MPS has not been adjusted-still sealed. Where can I purchase a replacement TPS and how hard is it to replace and calibrate? -Rick Seal Beach It's pretty easy to replace if you can use a hand drill and rivet tool. Kit is available here: https://900designs-container.zoeysite.com/2...on-sensor-board Calibration procedure here (requires ohmmeter): https://www.pelicanparts.com/techarticles/9...alibrate_20.jpg You can test by unplugging the TPS connector. Car won't accelerate as well, but you can see if you're still having hiccups. |
Lo-Fi Version | Time is now: 20th June 2024 - 09:01 AM |
