nsargeant |
Newbie ![]() Group: Members Posts: 12 Joined: 27-August 17 From: Vincennes, In Member No.: 21,381 Region Association: Upper MidWest ![]() |
In the quest for a perfect running 914 im getting oh so close. In the past I have replaced the tps with a new one that fixed the severe bucking/hesitation. The car ran so much better after that. What I am trying to figure out now is a random hesitation/hiccup that happens mostly during steady throttle when I am cruising on a highway. If I drive 30 miles it might happen once or twice. It seems pretty minor compared to the bucking I was having with the old tps. If I recall it has had this hesitation since I have owned the car for the last 3 years. I know the distributor does have a pertronix module in it. Ive recently changed replaced a few things listed below but still have that little hiccup. What would you guys investigate next?
Replaced: Fuel pump/filter Installed SS lines plugs, wires, rotor, (cap still looked new) tps sensor |
nsargeant |
I replaced my tps last year so I would be less inclined to think it’s that. Got mine at 914 rubber. I noticed that my MPS didn’t have the epoxy on the back so somebody might have done some adjusting before me. I think I might put the distributor and give the advance unit a cleaning. I could understand sticking weights. Perhaps it might the sporadic ness of it. Short of testing the vacuum on the mps, anything else with it might be above my ability. Do I need to dismantle the whole distributor to clean it? Should I file and clean the trigger points while I have it apart?
Lo-Fi Version | Time is now: 20th June 2024 - 09:08 AM |
