nsargeant |
Newbie ![]() Group: Members Posts: 12 Joined: 27-August 17 From: Vincennes, In Member No.: 21,381 Region Association: Upper MidWest ![]() |
In the quest for a perfect running 914 im getting oh so close. In the past I have replaced the tps with a new one that fixed the severe bucking/hesitation. The car ran so much better after that. What I am trying to figure out now is a random hesitation/hiccup that happens mostly during steady throttle when I am cruising on a highway. If I drive 30 miles it might happen once or twice. It seems pretty minor compared to the bucking I was having with the old tps. If I recall it has had this hesitation since I have owned the car for the last 3 years. I know the distributor does have a pertronix module in it. Ive recently changed replaced a few things listed below but still have that little hiccup. What would you guys investigate next?
Replaced: Fuel pump/filter Installed SS lines plugs, wires, rotor, (cap still looked new) tps sensor |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
yes, clean off the trigger points. Oil at the bottom of the dizzy means the O rings on the outside body is old.Change it.
Lo-Fi Version | Time is now: 20th June 2024 - 09:05 AM |
