914Toy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 722 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California ![]() ![]() |
To the brain trust: re slight shudder when engaging the clutch in first gear to begin moving forward.
The clutch assembly is a Sachs brand 228 mm and was installed new about two years ago onto a new flywheel on my 2.7 911 engine, and now has some 5,000 street miles on it. Also new was the throw out bearing (Sachs) and nylon bush under the clutch fork. I expected to see some clutch disk "burn" deposit on the fly wheel and/or pressure plate. To my surprise, while there were some small deposits on the flywheel and pressure plate, these parts and the clutch disk appear to be in near new condition - little measurable or obvious wear. However, the tips of the pressure plate "fingers (see pic) were worn down where the throw out bearing (TOB) contacts them. This suggests the TOB is slipping on the finger tips causing friction and wear. The TOB feels solid and spins freely like new. I don't believe this is normal wear. Any thoughts/advice? ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Wow that wear looks more like wear after 50,000 miles,not sure if the pic makes it that way but the wear looks uneven which may suggest the p/plate is faulty ?.
Could be that some of the fingers are weak if the wear is indeed uneven as mentioned,reason for saying this is I had a 200mm T1 p/plate do the same thing. I agree that a overly tight cable could cause this,is the pedal stop adjusted correctly ?,I found this a bit of a fiddle but ended putting it back where the original marks were in the wood floorboard. Good luck. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:34 AM |
