dashboard issues |
dashboard issues |
dax1969 |
Mar 20 2020, 04:20 AM
Member Group: Members Posts: 372 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Hi guys,
Sorting out the last electric gremlins so I can get the car inspected/registered. What I did so far : * installed hella front euro headlights * renewed the rubber under the dashpad so the horn works * installed new pin at the rear light switch so back up lights work * adjusted switch at the brakepedal so breaklights work * installed jwest fusepanel with led fuses - no blown fuses * in short all the external lights work, hazard, blinkers, mean and high beam, fogs etc One last thing I am looking for are the dashboard lights. I have the green and red light of the oil, dashboard light and the little green bulb of the citylights work. I don't have the blue high beam, no blinkerlights left and right, no hazard. I checked all grounds, they all look good...cleaned the one under the fusebox. Removed indicator and wiperstalk, took off the tubes for the windscreenwasher (have electrical pump installed). Opened the dashboard and checked the gauges... had two loose wires but most probably ripped them off when removing the panel. Noticed nothing special but was a bit worried (too many wires (IMG:style_emoticons/default/biggrin.gif) ) and re-installed everything. Now I have the indicator lights but instead of left right they blink together (so bulb is ok) BUT now my wiper remains on (not constantly every 10 seconds or so). My next guess was to replace both the indicator and wiperstalk but apparently the wiperstalk is NLA... No idea what to do next ... shall I remove and disconnect all the gauges, clean all connections, but new bulbs and clean the grounds and hope for the best ? I've read everything I could find (most tell it is a ground issue but they all look so clean, with no corrosion whatsoever) so any suggestions are welcome So close, only the few lights keep me away fm inspection/registration. (IMG:style_emoticons/default/evilgrin.gif) (IMG:style_emoticons/default/evilgrin.gif) thks Dax |
FlacaProductions |
Mar 20 2020, 01:37 PM
Senior Member Group: Members Posts: 1,736 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I would source a 4th screw if you can and I'll try to dig up the photo that's in my head that shows where that tab goes.
dax1969 |
Mar 21 2020, 11:01 AM
I would source a 4th screw if you can and I'll try to dig up the photo that's in my head that shows where that tab goes. Hi, Just took everything apart and found where the connector goes. It goes on the left top side... screw through the little hole and the tab goes between the contacts of the indicator. Wiper works as it should. Will source a fourth screw as soon as the shops re-open (only food and pharmacists are open here). Still have the issues with the lights so took the middle gauge out. While checking two bulbs just crumbled in my hand. Ordered a dozen new ones online... will install the new ones soon and see what the result is... thks for your help ! |
Lo-Fi Version | Time is now: 24th September 2024 - 01:12 PM |
