> 73 headlight issues, Lights pop up, won't turn on
pastormacman
post Mar 23 2020, 10:43 AM
So I searched and read through this thread:
http://www.914world.com/bbs2/index.php?sho...eadlight++relay
But it didn't quite cover what I was looking for. But I did notice a couple of people asking if the car was a '73. Mine is a '73. But I didn't see anyone say why that mattered. Is there something specific about the '73 model that has headlight issues?
Anyway, here's my issue: With the battery connected and the ignition switch on, when I pull out the headlight switch, both lights flip up but neither lights up.
A little history: This is the same car that you all have been helping me get started in this thread:
Part of the problem this community helped me figure out was that my ignition switch was broken. So I replaced it with a new one. So I have a new, working ignition switch.
I thought that maybe the high beam/low beam relay had gone bad, so I bought a new one from Automobile Atlanta. Like you can see in the pic, it has five posts, and the description says that it fits 70-76 914. However, when I removed the old one from the car, it only had four posts and four wires connected. So I connected the wires to the corresponding posts on the new relay and left the fifth post empty.
After installing the relay, I still had the same problem: The lights flip up, but won't turn on.
Another monkey wrench: my turn signal stalk is broken. The internal mechanism flops around all over the place and the turn signal swings loosely. I know that the turn signal stalk is also the high beam/low beam switch so I'm wondering if that could cause the lights to not turn on.
What are your thoughts?
dr914@autoatlanta.com
post Mar 23 2020, 11:40 AM
porsche changed the design, the new ones have five terminals, so you have one of the old original four terminal ones. Simply jump from the 12 oclock position to the 9 oclock position and it will work perfectly. If the headlights do not turn on at all on any beam, you may have a bad headlight switch Attached Image
QUOTE(pastormacman @ Mar 23 2020, 09:43 AM) *
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 04:20 PM
