2.0 Cylinder Gaskets, Should they be used? |
jack20 |
Apr 9 2020, 12:43 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Hello,
I had leaking pushrod tube seals and dropped the engine to make the job easier. I decided to pull the heads to check condition. I’ve done quite a bit of reading about whether or not gaskets should be used between the cylinder and case and between the cylinder and head. Some posters point to a service bulletin stating not to use gaskets. I have metal spacers/gaskets between the heads and cylinders. I think this engine has been rebuilt once before I got it. It runs well but it’s not as quick as another 914 2.0 I had years ago. Maybe the other car had higher compression and no gasket? I’m wondering if this metal gasket should be there. I haven’t checked for a gasket between the cylinder and case. My 356 has a thin copper gasket between the cylinder and case. Can anyone shed some light in this? Thanks in advance, Jack |
jack20 |
Apr 9 2020, 06:47 PM
You all have been very helpful. I appreciate it.
So VW put those metal gaskets in to reduce the possibility of oil leaks but cause a potentially bigger problem. Clay, you were correct about opening a can of worms. I researched many old posts before asking the questions. I wondered what the current thinking is. Obviously I’m no journeyman mechanic but have done a little of the type of work on other air cooled engines. If I leave the head gaskets out, will deck height be effected to a point where I will have problems with too high compression or any other problem? Thanks to all. Jack |
Lo-Fi Version | Time is now: 25th June 2024 - 10:46 PM |
