Ampex351 |
Member ![]() ![]() Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest ![]() |
The the transmission on my '73 shifts nicely through all gears except 5th. What the heck would cause 5th to grind? linkage need adjustment? Time for a rebuild?
What? Where do I start? |
billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States ![]() |
Start with checking/replacing all the shift bushings and adjustment
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Start with checking/replacing all the shift bushings and adjustment (IMG:style_emoticons/default/agree.gif) You have to do this methodically. First, make sure all bushings and linkages are functional and properly installed. Then you need to make sure everything is adjusted within it's proper range. Lots of threads on this out there. Here are a couple: Bushing replacement, in general: http://www.914world.com/specs/fwsb_replace.php Shift linkage adjustment: http://www.914world.com/bbs2/index.php?showtopic=188120 another, http://www.914world.com/bbs2/index.php?showtopic=91028 Use whatever procedure (Dr. Evil's, or Chris') works for you. Reading through them helps understand how everything is supposed to work. Only after checking all that should you consider tearing into the gearbox. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:52 AM |
