jack20 |
Member ![]() ![]() Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California ![]() ![]() |
Hello,
I had leaking pushrod tube seals and dropped the engine to make the job easier. I decided to pull the heads to check condition. I’ve done quite a bit of reading about whether or not gaskets should be used between the cylinder and case and between the cylinder and head. Some posters point to a service bulletin stating not to use gaskets. I have metal spacers/gaskets between the heads and cylinders. I think this engine has been rebuilt once before I got it. It runs well but it’s not as quick as another 914 2.0 I had years ago. Maybe the other car had higher compression and no gasket? I’m wondering if this metal gasket should be there. I haven’t checked for a gasket between the cylinder and case. My 356 has a thin copper gasket between the cylinder and case. Can anyone shed some light in this? Thanks in advance, Jack |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
Don't stack jug base shims.
A single .8mm shim should get you the 1mm deck minimum since usually you will have at least .2mm without one. Determining what base shim you need is easy. Just measure what you have without any shim at TDC. Subtract that number from 1mm and that's what you need. If you need more than 1mm to hit your target CR subtract what you have from what the required deck ht is. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:00 PM |
