> Wiring Appearance Group Gauges & Rear Defrost Light, : Where do these go?
914_7T3
post Apr 6 2020, 04:44 PM
Just buttoning up the appearance group gauges on my '73 and was not sure where these wires go.
First up is the ground wire with round connector that splits off from where the harness attaches back into the connectors in the tunnel. Does this screw onto the underside of the shifter base under the defrost light?
Also where does the black and green wire attach to?
Everything else seems pretty clear as far as matching the correct color wire out of the harness to the appropriate connector in the tunnel.
The green and ground for the rear defrost glass are present as well as are the 3 wires for the backpad light, so should be good to go from here.
JOEPROPER
post Apr 11 2020, 12:23 PM
The answer is "no" unless you ask...
(IMG:style_emoticons/default/icon_bump.gif) Bumping this thread because it helped me today! (IMG:style_emoticons/default/smilie_pokal.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 10:05 PM
