MSD & Pertronix ignitors, Is there any history of problems? |
Gatornapper |
Apr 12 2020, 08:46 PM
Senior Member Group: Members Posts: 1,259 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
It's looking like (diagnosis not really started - just happened tonight) I have had both a Pertronix and Hot-Spark ignitors get killed on my 914 on which I've had MSD since I got it.
Not sure about the Pertronix, but tonight both engine and tach started going haywire, then just suddenly died & lost all ignition at 60mph 3/4 mile from home. Had to tow car back. Something similar seemed to happen with the Hot-Spark a few weeks ago, only without the tach issue. I do have a .8ohm resister between the 12v from the ignition switch in front of the ignitor. Running an 050 dizzy and blue Bosche coil. Is there any history of MSD's killing electronic ignitors? Rickb45 just put in an MSD and not long afterwards, his Pertronix died too......... If not, any one have any ideas? Oh, my alternator runs low, generally 12.2 - 12.8v max with a good VR - have new alternator in my garage to put in ASAP. Pretty sure alternator is not putting out spikes, but really don't know as I do not have a recording oscilloscope...... ;-) GN |
IronHillRestorations |
Apr 13 2020, 08:47 AM
I. I. R. C. Group: Members Posts: 6,761 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've done several 6 conversion engine harnesses with MSD triggered by Pertronix Ignitor. I'll make it however the customer wants it configured, but I always caveat with my opinion on the Ignitor. If I make one now, I usually do a breakout wire in case the Ignitor fails and you've got to put points back in.
The Pertronix is not a mag pickup, even though it's got magnetic components, so using the green and purple mag pickup wires on the MSD is not correct, you use the same wire as a points distributor, you just have to get switched power to the Ignitor. No secret that I'm not a fan of Pertronix, and I know there's more guys that have had good service from them. I wish I never had problems as I think the concept is great. I guess I'm just on the anomaly side of the reliability factor. I do know you should delete the condenser, as you don't need it with an Ignitor. I put a brand new Pertronix SVDA distributor on a customer car(4 cyl) a few years ago, and it ran great for about 200 miles, and then dead as a rock. I found a 1.8 distributor with points and car was problem free. I felt bad for my customer as he was taking his wife out to dinner. I stood behind it and absorbed the cost to swap it out, but I won't do that again. In an MSD system the points are just a low voltage signal, so the only part that can give much trouble is the rubbing block, which should last for 5k miles or more without service. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:16 PM |
