gjames |
Newbie ![]() Group: Members Posts: 10 Joined: 3-March 13 From: Virginia Member No.: 15,606 Region Association: None ![]() |
My 914 had not run for 3 years. I soaked the cylinders in WD40 for a couple days before starting. I discovered heavy rust in the fuel tank so I replaced:
Tank, hoses and pump. Injectors and engine bay fuel lines And Flushed the long fuel lines until they ran clean The engine started but there was no power, poor idle I Replaced: Points/plugs/condenser/coil. Reset timing and idle (The dwell is no high side- 58) Power is back and idle is good. The Problem: When I give it gas, it will back fire into the throttle body. It seems to happen a 2k - 3k rpm range. It's doesn't happen every time. Ideas? |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
A couple of questions / points:
1. Which engine (e.g., 2.0) / injection system is this (or is it not FI)? 2. Were you seeing symptoms of something when you stopped driving it? 3. Agree, valves worth checking 4. Set dwell to 45 - 50 and THEN set timing. Changing timing will alter dwell. |
gjames |
A couple of questions / points: 1. Which engine (e.g., 2.0) / injection system is this (or is it not FI)? 2. Were you seeing symptoms of something when you stopped driving it? 3. Agree, valves worth checking 4. Set dwell to 45 - 50 and THEN set timing. Changing timing will alter dwell. Oops.....it's 2l with FI. I will reset the dwell and timing...and then the adjust the vales. thanks for the suggestions. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:46 AM |
