New Engine going in the car today, Finally ready to install |
DNHunt |
Dec 11 2004, 07:59 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Last thing I did was check the fluids and it's ready to go.
Attached image(s) |
DNHunt |
Dec 12 2004, 08:02 PM
Well, not exactly a raging success. First I couldn't get the starter to do anything. It turned out I had the 12 pin plug on the relay board in wrong. Wasted an hour. Then there was no switched 12 volt. I left the wire from pin 7 out of the wiring harness. An hour and a half. The fuel pump is only staying on for a second so I need to check that out.
So, I accomplished cranking it with the plugs out to build oil pressure and rebuilding my wiring harness. Got the clutch cable and speedo cable of the headers with a fabbed bracket. Haven't tried to fire it up yet. Maybe Tuesday evening. Dave |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:57 PM |
