> Need another nut for the rocker arm, assembly...
swood
post Dec 12 2004, 06:28 PM
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Where on this blasted car can I pick off another nut to replace the one that just got stripped?? I'm not in the mood to go find one as some store. I believe it's a 11mm.
(IMG:style_emoticons/default/chair.gif)
brp914
post Dec 12 2004, 08:40 PM
Unregistered
I believe the clutch cable also uses 7mm nuts (11mm wrench). Borrow 1 from there for today (only today!). But how did you strip that nut? Only needs 10 ft lb torque. Dont retighten before putting the valve cover back on - your valve adjustment will go away.
- Lo-Fi Version Time is now: 15th January 2025 - 10:08 AM
