1.7 d-jet '73 almost running |
isdyl |
Feb 29 2020, 06:15 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi all - so I've refitted d-jet on my 1.7 which had a single weber when I bought it. It's almost running but I've run out of ideas as to what to adjust or check. I've recorded a video of it starting. You'll hear that it starts quite lumpily and wants to stall. I manage to get the revs up by feathering the throttle and they go up to 2.5 or 3000 revs on their own for a second, and then it all dies again. I can keep it running by feathering the throttle again.
https://www.youtube.com/watch?v=Y06kdQC2IZg Fuel pressure when running is 2 BAR. Theres no cold start valve connected. All injectors are 'squirting' as I took them out and checked in a jam jar. I've tried adjusting timing, mixture screw, air screw. I haven't checked the valve clearances yet but have had the distributor in 100 different settings with no improvement. I just wondered if anyone has any ideas please? Thanks, Dylan |
isdyl |
Apr 15 2020, 10:07 AM
Hi,
I've spent a long time trying to improve the running now and think it's running too rich. My CH temp sensor is reading 4000 ohms and I think it should be nearer 2000 ohms. Would this cause it to run rich please, and is it a big job to change it? The wire goes into a hole in the tin but I can't work out if I have to remove the tin to get it out. Thanks, Dylan |
Lo-Fi Version | Time is now: 6th January 2025 - 04:56 PM |
