Engine's out again, problem found..., previous post about compression leak.. |
Mike D. |
Dec 9 2004, 12:04 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
So, this past weekend I dropped the 6 to look for a compression leak on the number three cylinder. As soon as the cooling shroud came off it didn't take long to find it.
It doesn't look too bad and now I will finally know for sure what pistons and cams I have. Also have to take care of an oil leak on the front somewhere. (or rear depending on what car or book (IMG:style_emoticons/default/smile.gif) ) Check it out. Attached thumbnail(s) |
Mike D. |
Dec 13 2004, 12:19 AM
QUOTE(sixnotfour @ Dec 12 2004, 10:05 PM) The cams are 130HP set 3.0-3.3mm 911/911L USA E cams = E distributor. On these old motors use should check the lift at overlap , in case they have changed or reground to a different profile than the P/N Hope this helps It doesn't look like much overlap if any. Is overlap measured in degrees of rotation, or in mm of valve travel at overlap? |
Lo-Fi Version | Time is now: 28th June 2024 - 05:45 PM |
