BPic |
Member ![]() ![]() Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States ![]() ![]() |
I hope you all are safe and well.
Trying to wrap up all the wiring connections. I have, based on my photos from 2 years ago and the wiring diagrams, all the wires connected correctly. However if I leave the running lights and headlights on for 5-10 minutes the housing on the headlight switch is almost to hot to touch. I really don't want to spend more money on a switch. Do you think that's what it is? Are they rebuildable? Thanks all! (IMG:style_emoticons/default/beerchug.gif) |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
All the current in the headlights indeed run through the headlight switch. One would need to add an extra relay to run higher power headlights. Might be a good time to switch to LED headlights.
Attached thumbnail(s) ![]() |
BPic |
@spoke - So no relay needed with LED? Maybe I'll bite the bullet and buy the ones we discussed on the phone.
Thank you! All the current in the headlights indeed run through the headlight switch. One would need to add an extra relay to run higher power headlights. Might be a good time to switch to LED headlights. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
@spoke - So no relay needed with LED? Maybe I'll bite the bullet and buy the ones we discussed on the phone. Thank you! All the current in the headlights indeed run through the headlight switch. One would need to add an extra relay to run higher power headlights. Might be a good time to switch to LED headlights. Get the ones from 914Rubber as they have the right pattern. I installed a set and they work great, much brighter so I installed them also on my Westy. I have H4 headlights now with LED bulbs, so much better |
Lo-Fi Version | Time is now: 26th June 2024 - 06:06 AM |
