Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Just finished the bugger.
Fired up 1st go around. Cold as crap outside so them 40 IDF's were spitting and sputtering for awhile. Richened up the idle mixture and ran like a champ. I will let it cool down and re-do the valves. |
Joe Ricard |
So Rob, Gots to remind you again. Don't forget the cooling tin. Crank that welder up tonight. Fix the tin Rob, Send the tin!!!!!
Spent the remainder of Saturday 4 hours playing with Carb linkage. Finally got them to open and close at the same rate. Tried every linkage arm in all the boxes I collected. Finally ended up drilling a slotted hole where I could fine tune the mechanical advantage to even out. |
Lo-Fi Version | Time is now: 25th June 2024 - 01:12 AM |
