Pilot Bearing, Installation |
Rhodes71/914 |
Dec 12 2004, 04:04 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Can the pilot bearing be installed into the flywheel without a press. I do have a vise. Any good easy methods?
DNHunt |
Dec 13 2004, 08:59 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
The pilot bearing does sit in the flywheel. It should be 3.2mm recessed to leave space for the felt washer. There is a spacer in the end of the crankshaft that prevents the pilot bearing from being installed to deeply.
Miy spacer was missing in the new crank and the only one I could find new was from Porsche in a warehouse in Germany. I finally made one from some pipe I had around. I don't recall the dimensions. It just took some measuring and fitting. If I remember it was a pilot bearing installed in the crank instead of the flywheel that ate SirAndy's input shaft seal. Dave |
Lo-Fi Version | Time is now: 24th September 2024 - 01:08 PM |
