1.7 d-jet '73 almost running |
isdyl |
Feb 29 2020, 06:15 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi all - so I've refitted d-jet on my 1.7 which had a single weber when I bought it. It's almost running but I've run out of ideas as to what to adjust or check. I've recorded a video of it starting. You'll hear that it starts quite lumpily and wants to stall. I manage to get the revs up by feathering the throttle and they go up to 2.5 or 3000 revs on their own for a second, and then it all dies again. I can keep it running by feathering the throttle again.
https://www.youtube.com/watch?v=Y06kdQC2IZg Fuel pressure when running is 2 BAR. Theres no cold start valve connected. All injectors are 'squirting' as I took them out and checked in a jam jar. I've tried adjusting timing, mixture screw, air screw. I haven't checked the valve clearances yet but have had the distributor in 100 different settings with no improvement. I just wondered if anyone has any ideas please? Thanks, Dylan |
euro911 |
Apr 20 2020, 12:22 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I didn't read through all the replies so I'll ask: Did you ever spray a 'combustible' liquid or vapor around the motor while it was idling to locate any vacuum leaks? It's the easiest method to find them (IMG:style_emoticons/default/idea.gif)
isdyl |
Apr 20 2020, 02:11 PM
Hi, I haven't actually, but that's mainly because it won't stay running. I've definitely got an improvement today after curing some leaks, and now she starts up fine, and idles for about 5 seconds at about 1400rpm, and then starts to die. I can keep the engine running by pumping the throttle, but after a few more seconds she starts to die again. It really feels like the fuel is running out. Pressure gauge stays at 29 psi.
Dylan I didn't read through all the replies so I'll ask: Did you ever spray a 'combustible' liquid or vapor around the motor while it was idling to locate any vacuum leaks? It's the easiest method to find them (IMG:style_emoticons/default/idea.gif) |
ctc911ctc |
Apr 20 2020, 03:06 PM
Senior Member Group: Members Posts: 948 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Does it die as if you turned the key off? Or does it stutter and stammer on its way to zero?
Pretty certain that there is a starting phase and then a running phase of the analog logic within the ECU. CHT? Did you change it? Are you certain that the CHT wire is connected to the ECU? This is what I would check next. I saw that you measured it cold. Cheap part, though hard to replace. Hi, I haven't actually, but that's mainly because it won't stay running. I've definitely got an improvement today after curing some leaks, and now she starts up fine, and idles for about 5 seconds at about 1400rpm, and then starts to die. I can keep the engine running by pumping the throttle, but after a few more seconds she starts to die again. It really feels like the fuel is running out. Pressure gauge stays at 29 psi. Dylan I didn't read through all the replies so I'll ask: Did you ever spray a 'combustible' liquid or vapor around the motor while it was idling to locate any vacuum leaks? It's the easiest method to find them (IMG:style_emoticons/default/idea.gif) |
isdyl |
Apr 21 2020, 04:39 AM
Not quite as quickly as if the key is switched off. I think I need to post an updated video later to see if that demonstrates the current symptoms more clearly.
I measured the CHT from the pin on the ecu loom to the battery earth, so unless the pin isn’t making proper contact with the ecu board maybe? How critical is the type of fuel filter please? The pressure is showing 2 bar but is it possible the flow could be low even if the pressure shows ok? I currently have a clear plastic inline filter before the pump. Regards Dylan Does it die as if you turned the key off? Or does it stutter and stammer on its way to zero? Pretty certain that there is a starting phase and then a running phase of the analog logic within the ECU. CHT? Did you change it? Are you certain that the CHT wire is connected to the ECU? This is what I would check next. I saw that you measured it cold. Cheap part, though hard to replace. Hi, I haven't actually, but that's mainly because it won't stay running. I've definitely got an improvement today after curing some leaks, and now she starts up fine, and idles for about 5 seconds at about 1400rpm, and then starts to die. I can keep the engine running by pumping the throttle, but after a few more seconds she starts to die again. It really feels like the fuel is running out. Pressure gauge stays at 29 psi. Dylan I didn't read through all the replies so I'll ask: Did you ever spray a 'combustible' liquid or vapor around the motor while it was idling to locate any vacuum leaks? It's the easiest method to find them (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 6th January 2025 - 04:46 PM |
