Joseph Mills |
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 ![]() |
After removing the four star bolts from the outer CV joint (at the wheel), I removed the axle with the circlip, cage and balls in place (which are all in good shape). However, the CV joint "hub" itself (with the two guide pins) has not budged from the "wheel hub flange".
With the inner CV joint (next to the transaxle), the hub is totally exposed and a few taps with a hammer and then careful prying with a screwdriver and the hub comes right off the "transaxle flange". But since the outer hub is located deep inside the suspension arm, it is difficult to get to. Any advice, tips, or tools that may help me break this thing loose? |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) with John. It's not extreme or costly to loosen a 30mm nut and slide the entire assembly out so you can perform the task in sunlight.
Good luck. Let us know what you end up doing. (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 07:51 AM |
