1.7 d-jet '73 almost running |
isdyl |
Feb 29 2020, 06:15 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi all - so I've refitted d-jet on my 1.7 which had a single weber when I bought it. It's almost running but I've run out of ideas as to what to adjust or check. I've recorded a video of it starting. You'll hear that it starts quite lumpily and wants to stall. I manage to get the revs up by feathering the throttle and they go up to 2.5 or 3000 revs on their own for a second, and then it all dies again. I can keep it running by feathering the throttle again.
https://www.youtube.com/watch?v=Y06kdQC2IZg Fuel pressure when running is 2 BAR. Theres no cold start valve connected. All injectors are 'squirting' as I took them out and checked in a jam jar. I've tried adjusting timing, mixture screw, air screw. I haven't checked the valve clearances yet but have had the distributor in 100 different settings with no improvement. I just wondered if anyone has any ideas please? Thanks, Dylan |
isdyl |
Apr 24 2020, 11:42 AM
Plugs are very sooty so maybe too much fuel? Question - If the return to the fuel tank was blocked, would this show up as high fuel pressure at the injector rail or not please?
D |
Lo-Fi Version | Time is now: 6th January 2025 - 05:00 PM |
