> Cam Swap, Engine All Together
dereknlee
post Apr 25 2020, 09:27 AM
I have a decision to make and could use some advice. My 1.7 engine was completely re-built into a 2 liter in 2012 by a local shop. At the time the plan was to run 40 IDFs so a Webcam 86 (00-152) cam was installed. My 914 hasn't driven since 2008 and has been an on-again/off-again project ever since, so the rebuilt long block has never run.
Well the 914 project is back on again and in the intervening years I've decided to stick with D-jet. I talked with Webcam, they said the 86 grind isn't too different but that they recommend a 73. And they generously offered to exchange for the cost of shipping (assuming the cam condition is as new).
Swapping the cam is a bit intimidating as a project, but I have some engine rebuild experience and have done enough wrenching that I think I could muddle through.
My questions are as follows:
1) If in my shoes would anyone not change the cam? My consensus from searching this forum is that the 73 is the grind to go with for injection and 86 is for carbs. But the conversations are usually had while someone is doing a rebuild anyway and looking for the optimal cam.
2) Is there a minimally invasive way to get to the cam, or should I just follow engine rebuild instructions and pull everything apart? Haven't found anything in my searches on this or other forums to suggest there is any option here.
3) Should I really just have a shop do this? The warranty on the rebuild has long expired. But the possibility for mistakes that could take down the otherwise good rebuild abound (or so I fear). Are there any steps in this process that require experience or special tools that someone who is book taught on this process is likely to mess up?
Here's a picture, because walls of text are boring:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-14259-1587828462.1.jpg)
Thanks!
-Derek
PlaysWithCars
post Apr 25 2020, 10:23 PM
QUOTE(jd74914 @ Apr 25 2020, 04:28 PM) *
do You have a complete and known working D Jet system for the 2L?
If not, and you’re considering paying someone to break the engine down and can swap (which will be a bunch of work and cost since the pushrods will have to be remade with the new geometry, etc), why not instead switch to a more modern EFI system? Even the simplistic system can be tuned to work with a ‘carb’ cam with little difference than an old FI grind. Cost may not be so different, and you won’t have to deal with old electronics. If you’re not too concerned about the stock look, Mario at the dub shop seems to have some pretty nice setups which aren’t too costly.
Fuel injection (IMG:style_emoticons/default/beerchug.gif) over carbs, but I wouldn't spend the money to swap cams. I'd do as Jim suggests and build an FI system for the motor you have. You've noted that your motor isn't a stock 1.7 anymore, so the 1.7 FI system isn't going to function properly without some tweaking. Cam swap + FI tuning is probably going to cost as much or more as just building an FI system to match what you have. Instead of ending up with a non-original lower hp solution, why not embrace that its not stock and build an FI system to match the motor you already have?
I also think the color is great by the way.
dereknlee
post Apr 25 2020, 11:10 PM
QUOTE(PlaysWithCars @ Apr 25 2020, 09:23 PM) *
This is an interesting idea you both bring up. I have read that to get the Djet to work with the bigger engine the MPS will need to be adjusted. But nothing I read on the board suggested that was a particularly expensive or difficult job. Is there going to be more to it than that? The dubshop kit is almost $3k, seems like for that much I could almost undo the engine changes and go bone stock.
JamesM
post Apr 26 2020, 12:56 AM
QUOTE(dereknlee @ Apr 25 2020, 09:10 PM) *
The dubshop kit is a full system with induction which you wont need if you already have the d-jet manifold, throttle body, etc. ECU, wiring harness, crank sensor, possibly injectors are all you really need to convert d-jet to MS.
You never mentioned what d-jet setup you have, or what was done to convert your 1.7 to a 2.0 though. We know the current cam will be an issue with D-jet but there are other potential hiccups as well depending on the details. If you dont have a stock motor, and the correct matching d-jet system for that stock motor I probably wouldn't mess with d-jet. Im sure you can make it run, you might even make it run "ok".... I wouldn't expect more than that though.
dereknlee   Cam Swap, Engine All Together   Apr 25 2020, 09:27 AM
JOEPROPER   Not sure about changing the cam but, if the engine...   Apr 25 2020, 09:39 AM
thelogo   If you have the cam for carbs in there Then run...   Apr 25 2020, 09:39 AM
PanelBilly   I'd ask for Rich to help. If you're not su...   Apr 25 2020, 09:44 AM
TheCabinetmaker   It's not a v8. Cam change is a total breakdown...   Apr 25 2020, 10:01 AM
porschetub   Not a real big job as the motor is already recondi...   Apr 25 2020, 02:56 PM
Cairo94507   Hi Derek, Wow, that's a great looking 914 you...   Apr 25 2020, 03:38 PM
914werke   :agree: good lookin car. I DONT agree with the ca...   Apr 25 2020, 04:28 PM
jd74914   do You have a complete and known working D Jet sys...   Apr 25 2020, 05:28 PM
dereknlee   Lots of good ideas. I think Webers look sexy as...   Apr 25 2020, 09:27 PM
PlaysWithCars   do You have a complete and known working D Jet sy...   Apr 25 2020, 10:23 PM
porschetub   do You have a complete and known working D Jet s...   Apr 25 2020, 10:55 PM
dereknlee   :agree: Fuel injection :beer2: over carbs, but ...   Apr 25 2020, 11:10 PM
JamesM   :agree: Fuel injection :beer2: over carbs, but...   Apr 26 2020, 12:56 AM
GregAmy   Lots of good ideas. I think Webers look sexy a...   Apr 26 2020, 07:02 AM
dereknlee   You never mentioned what d-jet setup you have, or...   Apr 26 2020, 09:13 AM
JamesM   [quote name='JamesM' post='2808443' date='Apr 25 ...   Apr 26 2020, 11:03 PM
dereknlee   What is your ultimate end goal? Starting from wh...   Apr 27 2020, 06:00 PM
Bleyseng   Me? I go the 2.0l engine with a Djet setup and buy...   Apr 26 2020, 10:34 AM
bbrock   I'm no expert on this but I know I've read...   Apr 27 2020, 06:14 PM
Bleyseng   I'm no expert on this but I know I've rea...   Apr 27 2020, 06:27 PM
bbrock   I'm no expert on this but I know I've re...   Apr 27 2020, 07:27 PM
dereknlee   I've had enough on my hands bringing this rus...   Apr 27 2020, 07:34 PM
bbrock   I've had enough on my hands bringing this ru...   Apr 27 2020, 08:25 PM
914werke   My searches led me to believe that Djet would wor...   Apr 27 2020, 06:42 PM
Bleyseng   We should meet up at 914Werke one day. :Qarl:   Apr 27 2020, 07:12 PM
dereknlee   We should meet up at 914Werke one day. :Qarl: ...   Apr 27 2020, 07:25 PM
Mark Henry   Get a stock 2.0 intake system and run MS or SDS EF...   Apr 28 2020, 05:51 AM
- Lo-Fi Version Time is now: 14th March 2025 - 11:25 AM
