> Cam Swap, Engine All Together
dereknlee
post Apr 25 2020, 09:27 AM
I have a decision to make and could use some advice. My 1.7 engine was completely re-built into a 2 liter in 2012 by a local shop. At the time the plan was to run 40 IDFs so a Webcam 86 (00-152) cam was installed. My 914 hasn't driven since 2008 and has been an on-again/off-again project ever since, so the rebuilt long block has never run.
Well the 914 project is back on again and in the intervening years I've decided to stick with D-jet. I talked with Webcam, they said the 86 grind isn't too different but that they recommend a 73. And they generously offered to exchange for the cost of shipping (assuming the cam condition is as new).
Swapping the cam is a bit intimidating as a project, but I have some engine rebuild experience and have done enough wrenching that I think I could muddle through.
My questions are as follows:
1) If in my shoes would anyone not change the cam? My consensus from searching this forum is that the 73 is the grind to go with for injection and 86 is for carbs. But the conversations are usually had while someone is doing a rebuild anyway and looking for the optimal cam.
2) Is there a minimally invasive way to get to the cam, or should I just follow engine rebuild instructions and pull everything apart? Haven't found anything in my searches on this or other forums to suggest there is any option here.
3) Should I really just have a shop do this? The warranty on the rebuild has long expired. But the possibility for mistakes that could take down the otherwise good rebuild abound (or so I fear). Are there any steps in this process that require experience or special tools that someone who is book taught on this process is likely to mess up?
Here's a picture, because walls of text are boring:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-14259-1587828462.1.jpg)
Thanks!
-Derek
bbrock
post Apr 27 2020, 06:14 PM
I'm no expert on this but I know I've read several times that D-Jet is good up to a 2056 engine. I'm in a similar situation as you. Thirty years ago I got tired of being stranded by a worn out D-Jet system in my 73 2.0L. The engine was due for a rebuild anyway so I tore it down and rebuilt the bottom end bone stock except with Euro spec pistons and a carb cam to match a pair of Webers purchased at the same time. Life happened and 30 years later, I'm just now at the point of finishing what I started. If I started today, I would have refurbished the D-Jet but given I have the carbs and the cam is already installed, I'm going to run with them for awhile. Maybe I'll tear it down and swap cams at a later time but that is TBD.
Bleyseng
post Apr 27 2020, 06:27 PM
Aircooled Baby!
QUOTE(bbrock @ Apr 27 2020, 05:14 PM) *
I have had my 2.0L car running Djet since I put it back on since 1998. It has failed once with a dead CHT in my driveway! Worn out parts hmm- you can buy new 123 dizzys now, injectors, rebuilt MPS's, etc... What the heck failed you all the time?
There are still 2.0L Djet setup's out there for someone to install on their car to make it "original".
I still have yet to drive a Megasquirt 2056 that runs as strong as mine. Do your homework as there are soo many possibilities..
bbrock
post Apr 27 2020, 07:27 PM
QUOTE(Bleyseng @ Apr 27 2020, 06:27 PM) *
Remember, this was over 30 years ago. It was the 80s. There was no Internet and for sure nobody near me that knew anything about these fuel injections - not that I had any money to pay them if there were. Hell, the last tank of gas I put in that car was leaded!
But to answer your question, it was usually wiring that left me stranded although I did spend a lovely afternoon in Texas diagnosing an advance weight spring that had flown loose from the dizzy. Another time it was the injector trigger points. Another hot day on the shoulder of I-70 cobbling a patch for a fried tach wire. Luckily I had a roll of electrical tape and extra set of points in the car. There was more wrong because even when it ran during the last couple years on the road, it didn't run well.
Back then, ripping the D-Jet off and installing carbs was what all the cool kids were doing so that's what I decided to do. I think a Weltmeister kit with brand new Italian made 40IDFs set me back less than $200. Much cheaper than getting the FI fixed at the time. Like I said, today I would have stuck with the D-Jet. Better info available, a little more money, better understanding of the advantages, etc. I still plan to go through the D-Jet and make it like new but since the carb cam was sealed in the case decades ago and I have the carbs, I'm running with them for now. Going back to D-Jet will be a project for the future. I've had enough on my hands bringing this rust bucket back to life.
dereknlee
post Apr 27 2020, 07:34 PM
QUOTE(bbrock @ Apr 27 2020, 06:27 PM) *
I've read through every page of your build thread since re-starting work on my car this month. Amazing work, I'm in awe! I really appreciate all the detailed info on almost every facet of the build, it is a great resource for those of us following behind with our own projects.
-Derek
dereknlee   Cam Swap, Engine All Together   Apr 25 2020, 09:27 AM
JOEPROPER   Not sure about changing the cam but, if the engine...   Apr 25 2020, 09:39 AM
thelogo   If you have the cam for carbs in there Then run...   Apr 25 2020, 09:39 AM
PanelBilly   I'd ask for Rich to help. If you're not su...   Apr 25 2020, 09:44 AM
TheCabinetmaker   It's not a v8. Cam change is a total breakdown...   Apr 25 2020, 10:01 AM
porschetub   Not a real big job as the motor is already recondi...   Apr 25 2020, 02:56 PM
Cairo94507   Hi Derek, Wow, that's a great looking 914 you...   Apr 25 2020, 03:38 PM
914werke   :agree: good lookin car. I DONT agree with the ca...   Apr 25 2020, 04:28 PM
jd74914   do You have a complete and known working D Jet sys...   Apr 25 2020, 05:28 PM
dereknlee   Lots of good ideas. I think Webers look sexy as...   Apr 25 2020, 09:27 PM
PlaysWithCars   do You have a complete and known working D Jet sy...   Apr 25 2020, 10:23 PM
porschetub   do You have a complete and known working D Jet s...   Apr 25 2020, 10:55 PM
dereknlee   :agree: Fuel injection :beer2: over carbs, but ...   Apr 25 2020, 11:10 PM
JamesM   :agree: Fuel injection :beer2: over carbs, but...   Apr 26 2020, 12:56 AM
GregAmy   Lots of good ideas. I think Webers look sexy a...   Apr 26 2020, 07:02 AM
dereknlee   You never mentioned what d-jet setup you have, or...   Apr 26 2020, 09:13 AM
JamesM   [quote name='JamesM' post='2808443' date='Apr 25 ...   Apr 26 2020, 11:03 PM
dereknlee   What is your ultimate end goal? Starting from wh...   Apr 27 2020, 06:00 PM
Bleyseng   Me? I go the 2.0l engine with a Djet setup and buy...   Apr 26 2020, 10:34 AM
bbrock   I'm no expert on this but I know I've read...   Apr 27 2020, 06:14 PM
Bleyseng   I'm no expert on this but I know I've rea...   Apr 27 2020, 06:27 PM
bbrock   I'm no expert on this but I know I've re...   Apr 27 2020, 07:27 PM
dereknlee   I've had enough on my hands bringing this rus...   Apr 27 2020, 07:34 PM
bbrock   I've had enough on my hands bringing this ru...   Apr 27 2020, 08:25 PM
914werke   My searches led me to believe that Djet would wor...   Apr 27 2020, 06:42 PM
Bleyseng   We should meet up at 914Werke one day. :Qarl:   Apr 27 2020, 07:12 PM
dereknlee   We should meet up at 914Werke one day. :Qarl: ...   Apr 27 2020, 07:25 PM
Mark Henry   Get a stock 2.0 intake system and run MS or SDS EF...   Apr 28 2020, 05:51 AM
- Lo-Fi Version Time is now: 17th September 2026 - 10:24 PM
