Lilchopshop |
Member ![]() ![]() Group: Members Posts: 75 Joined: 17-February 20 From: New York Member No.: 23,932 Region Association: North East States ![]() |
Pulled my rocker covers today to inspect for rot. Unfortunately I found significant rust on both jack points and the driver’s side long has a good size rust hole. I’m going to cut and patch the bad spots in the longs, but I’m trying to avoid a complete resto right now and I don’t want to get into exterior bodywork. The rear fenders are in pretty good shape but they seem to block access to the top flange of the jack point plate. Does anyone know if the jack points can be replaced correctly without cutting out a lower portion of the rear fender?
Attached thumbnail(s) ![]() Attached image(s) ![]() ![]() |
Lilchopshop |
I’ve been chipping away at this project over the past couple of weeks and have made some progress on the passenger side repairs. As with any project like this, there has been considerable scope growth... one thing I am now considering is the addition of a inner long stiffener kit from Mad Dog Motorsports. I figure, since I’m here, now is the right time to do this... the question I have for all of you is, when should I install the stiffeners? Right now, I am just about ready to close up the passenger side long with the new inner rocker panel from RD. Before I do this, I want to coat the inside of the long with something for rust prevention. If I weld on a longitudinal stiffener after I coat the inside, some of the coating will burn off, but if I install the stiffener before I close up the long, I’m worried about warpage. Which is the lesser of the two evils? Anyone have any thoughts?
Attached thumbnail(s) ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 07:35 AM |
