bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Okay, I just got a quote for re-chroming inner and outer door handles, early window crank bases, and the side mirror mount and post of $800. All of a sudden I'm seeing the minor blemishes on the parts as "charming patina." (IMG:style_emoticons/default/smile.gif)
Plan B is to just polish them up as best I can. They are all in pretty good shape. Mostly I'd like to get rid of some fine scratches on the outer door handles if possible (Looks like maybe they were cleaned with a scrubber sponge at some point). Anyone have suggestions on buffing wheels, compounds, techniques, etc.? I already went over most of the parts with Mother's which, of course, shined up the chrome but door handles will need a little more aggressive polishing I think. ![]() |
914e |
Member ![]() ![]() Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region ![]() ![]() |
Mothers on a cotton Dremel buffing wheel worked pretty well for me in the small areas. The Mothers on a 2-3 foam pad in drill worked on larger areas.
It seems to work pretty well on hard plastics as well. I picked up a head light polishing kit to see if that does any better on the plastics. I'm not having much luck with the anodized aluminum I can't get rid of the clouding. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,994 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Mothers on a cotton Dremel buffing wheel worked pretty well for me in the small areas. The Mothers on a 2-3 foam pad in drill worked on larger areas. It seems to work pretty well on hard plastics as well. I picked up a head light polishing kit to see if that does any better on the plastics. I'm not having much luck with the anodized aluminum I can't get rid of the clouding. @914e Anodized aluminum doesn't polish well as you've noted. You'll need to sand off the anodize layer and then polish the raw aluminum and do regular maintenance polishing. You can also have the anodize chemically stripped, polished, and then reannodized clear to avoid the maintenance polishing. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:28 AM |
