> Help with fuel tank venting
flipb
post May 15 2020, 08:31 AM
I replaced the seal under the fuel cap a few years ago, and I recently realized that the fuel tank is forming an airtight vacuum as it drains. In fact I recently burned out and replaced a fuel pump, and in hindsight, I realized it probably burned out due to pulling against vacuum pressure in the tank.
When I remove the gas cap after a drive, there is a very noticeable suction.
My question is: What's the proper routing for charcoal canister and fuel tank ventilation? I'm running carbs on a 2056cc engine. Photo here of the canister... the other end of the hoses seem to be loose/uncapped in the engine bay but could be kinked/blocked somewhere.
ClayPerrine
post May 15 2020, 12:02 PM
The other end of the hoses in the engine compartment have to be hooked up. The one that connects to the side of the charcoal canister that has the small tank connection should hook to the fan shroud. the other one needs to hook to one of your air filters.
The idea is that the fan pushes air through the canister, and that sucks up the gas fumes from the tank, and carries them back to the intake so they can be burned in the engine.
- Lo-Fi Version Time is now: 28th January 2025 - 05:22 PM
