Help with fuel tank venting |
flipb |
May 15 2020, 08:31 AM
Senior Member Group: Members Posts: 1,784 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
I replaced the seal under the fuel cap a few years ago, and I recently realized that the fuel tank is forming an airtight vacuum as it drains. In fact I recently burned out and replaced a fuel pump, and in hindsight, I realized it probably burned out due to pulling against vacuum pressure in the tank.
When I remove the gas cap after a drive, there is a very noticeable suction. My question is: What's the proper routing for charcoal canister and fuel tank ventilation? I'm running carbs on a 2056cc engine. Photo here of the canister... the other end of the hoses seem to be loose/uncapped in the engine bay but could be kinked/blocked somewhere. |
Mikey914 |
May 15 2020, 12:59 PM
The rubber man Group: Members Posts: 12,745 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Could be it.
You are running a return line back to the tank, right? |
Lo-Fi Version | Time is now: 28th January 2025 - 05:20 PM |
