Solved!: Rear Lighting Electrical Gremlins |
scottthephotog |
May 15 2020, 05:29 PM
Member Group: Members Posts: 187 Joined: 20-November 18 From: Euless, TX Member No.: 22,667 Region Association: Southwest Region |
So I've been chasing electrical gremlins with the rear lighting since I bought the car a year and a half ago, and from what I can tell, the previous owner was as well (but just didn't mention it during the sale). The front lighting works as it should.
Here are the symptoms: with the parking lights/headlights off
Any thoughts or suggestions? The front lights work perfectly fine, so I'm leaning towards a wiring issue. Are the front and rear lights split at the hazard light switch that part of the switch could have failed? I also can't figure out why the licence plate lights, reverse lights and brake lights are affected by this. |
framos914 |
May 15 2020, 08:54 PM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
I had strange things happen with my lighting that didn't make sense because the circuits weren't related. Found a couple of wires on my light switch had bare spots and were touching. This was after I had been doing some work with the wiring.
Start with a good wiring diagram and try to isolate the circuits. A few circuits have the emergency flasher switch in common. Make sure all are connected to the correct terminal. |
scottthephotog |
May 15 2020, 09:15 PM
I had strange things happen with my lighting that didn't make sense because the circuits weren't related. Found a couple of wires on my light switch had bare spots and were touching. This was after I had been doing some work with the wiring. Start with a good wiring diagram and try to isolate the circuits. A few circuits have the emergency flasher switch in common. Make sure all are connected to the correct terminal. I'll double check again tomorrow, but I didn't see any bare spots on the wires anywhere. I unplugged and cleaned all the connectors on switches and lights and double checked the all of the connections based on the wiring diagrams in workshop manuals and the wiring diagrams I've seen here on 914World for the switches and taillights. |
Sway Bar |
May 15 2020, 10:51 PM
Member Group: Members Posts: 88 Joined: 17-December 19 From: Okanagan Valley, Great White North Member No.: 23,743 Region Association: None |
I'm thinking a short/ground somewhere in or near the tail light assembly that makes it all behave weird.
I've been working on my car which was a parked roller for decades and it displayed all the same systems...front works fine but rear behaved funny. Some lights worked then turned on park lights and then didn't work etc etc.. Then one side worked so swapped bulbs and all of a sudden it didn't work. Everything cleaned, new bulbs/old bulbs, correct wiring etc. In my case it was 1 or 2 of the bulbs and sockets...clean as could be but if the bulb was turned/locked all the way funny results but if I twisted back the bulb a fraction all good and everything works great....so some are shorting slightly somehow in the socket. It will be something simple. |
Lo-Fi Version | Time is now: 31st October 2024 - 08:20 PM |
