Solved!: Rear Lighting Electrical Gremlins |
scottthephotog |
May 15 2020, 05:29 PM
Member Group: Members Posts: 187 Joined: 20-November 18 From: Euless, TX Member No.: 22,667 Region Association: Southwest Region |
So I've been chasing electrical gremlins with the rear lighting since I bought the car a year and a half ago, and from what I can tell, the previous owner was as well (but just didn't mention it during the sale). The front lighting works as it should.
Here are the symptoms: with the parking lights/headlights off
Any thoughts or suggestions? The front lights work perfectly fine, so I'm leaning towards a wiring issue. Are the front and rear lights split at the hazard light switch that part of the switch could have failed? I also can't figure out why the licence plate lights, reverse lights and brake lights are affected by this. |
framos914 |
May 16 2020, 04:52 AM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
I agree with Sway-Bar, it does sound like an issue with a short in the rear assembly bulbs or wiring.
Was looking at 73 wiring diagram and all those lights share the same ground point. But voltage for turn and flashers come from Emergency flasher switch. Stop lights, license plate lights, tail lights and back up come from their own separate switches and fuses. Maybe a good way to troubleshoot is to remove all rear light bulbs and reinstall one at a time. Rear side marker lights also use same ground. This old wiring can be a pain |
Lo-Fi Version | Time is now: 31st October 2024 - 08:20 PM |
