| ClayPerrine |
May 8 2020, 03:00 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Step 1. Buy these:
1980 Porsche 911SC Female Housing, 14 Pin 1983 Porsche 911SC Pin, Female 14 Pin Connector (you need 14 of these) 1969 Porsche 911 Lid, 14 Pin Plug 1969 Porsche 911 14 Pin Plug Male Kit Why Porsche chose to provide a kit for the Male plug, but make you purchase all of the pieces for the female connector separately we will never know. 2. Remove the connectors from the ends of the wires on the turn signal switch. Don't remove the one on the switch end Brown/White wire. That connects to the back of the horn wiper ring. 3. Strip the insulation off the wires, and solder on the pins for the MALE connector. You don't want to use the female end, because some of those wires can be hot with 12v if you use the male connector on the chassis harness side. 4. Put the pins into the bottom of the male connector. Make notes of the wire color associated with each pin number. 5. Install the top on the connector. 6. Remove the beam relay and disconnect the wires. There is a large yellow wire and a small yellow wire. Strip and solder on female pins to the large yellow, white and red/white wires. The small yellow wire is not going to be used. 7. Remove the plug that connects to the turn signal/wiper switches. The wires that connected to the wiper switch are not going to be used any more. Note: I like to take the time to completely remove the wires from the harness, but it is OK to leave them there. Just tape them off so they don't short anything. 8. Strip and solder the remaining female pins onto the brown/white, black/white, black/white/green, black/green, grey/red, grey/brown, grey, and red.white wires. 9. Install the female pins into the female connector base. Make sure you match the connections with the wires in the male connector. I like to put the female base on the male connector and install the pins to match. 10. Install the cover on the female connector. 11. Test the wiring. Make sure the turn signals work, the low and high beams work and make sure the park light lights on one side with the key off and the turn signal engaged. 12. Last and most important step. Have a beer and celebrate! Here is a chart of the wire connections for your reference. |
| Mark Henry |
May 20 2020, 09:25 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Thanks Clay bookmarked this thread.
I think I have the harnesses for the turn and wiper switches, but I'm missing the big round connector for the ignition switch I have. |
ClayPerrine How to wire up an early 911 turn signal switch into a 914-4 harness May 8 2020, 03:00 PM
mb911 Thanks so much.. Its on order.. Still have to figu... May 8 2020, 03:48 PM
ClayPerrine
Thanks so much.. Its on order.. Still have to fig... May 8 2020, 05:22 PM
ClayPerrine And if you run into any problems with the wiring, ... May 8 2020, 05:23 PM
mb911 Sounds good.. Thanks May 8 2020, 05:35 PM
GregAmy What's the advantage of the 911 one? May 9 2020, 10:52 AM
mb911
Left ... May 9 2020, 10:55 AM
mb911 @ClayPerrine my beam relay has a yellow with Red ... May 10 2020, 01:37 PM
ClayPerrine
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 10 2020, 07:00 PM
mb911 So this bundle of wires won't get used? May 13 2020, 07:20 PM
ClayPerrine
N... May 14 2020, 07:40 AM
mb911 This is harness side and must have plugged into th... May 14 2020, 01:32 PM
ClayPerrine
This is harness side and must have plugged into t... May 15 2020, 12:14 PM
mepstein Thank you Clay :beer2: May 15 2020, 01:57 PM
mb911 Ok done and done meaning soldered ends, had a beer... May 16 2020, 06:08 PM
mb911 Well plot thickens.. Found out the yellow wire was... May 16 2020, 08:35 PM
mb911 Problem semi solved.. Was not getting 12v to the y... May 17 2020, 01:45 PM
ClayPerrine Ben,
I haven't forgotten about you. I spent t... May 18 2020, 04:38 AM
ClayPerrine Ben,
Do you have low beams?
Do you have park ... May 20 2020, 06:54 PM
mb911
Ben,
Do you have park... May 21 2020, 06:57 AM
ClayPerrine
Ben,
Do you have par... May 21 2020, 11:32 AM
mb911
[quote name='mb911' post='2817451' date='May 21 2... May 21 2020, 12:21 PM
ClayPerrine
[quote name='mb911' post='2817451' date='May 21 ... May 21 2020, 12:25 PM
mb911 I am still suspicious that the 911 ignition switch... May 21 2020, 12:36 PM
mb911 @superhawk996 Nov 15 2020, 05:37 PM
morehills
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 27 2024, 08:50 AM
mb911 Yup mine is all good. Ironically it was just the e... Jun 27 2024, 10:18 AM
morehills
Yup mine is all good. Ironically it was just the ... Jun 27 2024, 05:02 PM
mb911
Yup mine is all good. Ironically it was just the... Jun 28 2024, 05:12 AM
morehills
[quote name='morehills' post='3153516' date='Jun ... Jul 24 2024, 12:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th December 2025 - 05:18 AM |
